Surf2snow1
I got one from auto anything a couple weeks ago, took 3 days to show up. Think I got it for around $370… just had to ask them for a discountYup backorder also ,good luck
Got a Bakflip MX4 delivered... debating on whether to put it on now or wait until after bedliner (local Line-X is currently out of product and not sure when more will come).
I don't really want to install it twice...
Sent from my SM-G981U using Tapatalk
What wheels are these?? They are beautiful.
Bought from S&B?... I'm originally from the Wick!!!Installed the Bak MX4 coverView attachment 18277
Originally from Holland Marsh/Holland Landing, but now in Sutton.Bought from S&B?... I'm originally from the Wick!!!
Installed my new Husky fifth wheel adaptor for the puck system and installed my old fifth wheel hitch.
Then tested it out to see how level the trailer would be going from the 1/2 ton to the 3/4 ton.
Pin box and hitch are already maxed out for adjustment. going to need to reposition the leaf springs on the trailer a bit to get the trailer to sit more level. Luckly i have a few more holes left of adjustment there.
I hear you. I got sold this hitch when i bought the trailer. I have not had to slide it for any reason yet. Only time it might be handy is if hooking up or disconnecting at an angle so i can still drop the tail gate.They gave you adjustment holes on the leaf hangers? Wow.
P.S. That doesn't look like a slidebar head, but I had an old Husky slidebar head and I hated that thing. As safe as they are, they suck to hook or unhook and it was always binding. Made a lot of noise too.
The instructions drawings are wrong. For driver’s side assemble the two piece support as shows on passenger side or it will not line up. Sloppy work Amp research. Drove me nuts but finally figured it out out.
Installed Amp Research Bedstep2. The instructions drawings are wrong. For driver’s side assemble the two piece support as shows on passenger side or it will not line up. Sloppy work Amp research. Drove me nuts but finally figured it out out.
Have not ran into that yet. Hitch is available this way from Husky now a days. My dad had the former version that does not pivot side to side.
This one is surprisingly quite after i adjusted the set screws on the bottom of the slider rails.
Pictures attached of the trailer frame. I think 1 hole might be enough. Worried that dropping all the way to the bottom hole would allow too much stress.
This might help.What does the bracketry look like? I want to move my SRW AMP step to just forward of the wheel and need to put in some nutserts and fab or have made a bracket to connect to the spring hanger.
I hate that the only option was at the front of the bed as my toolbox makes it useless in that location.
Installed some Rough Country rear wheel well liners last night... was not as straightforward as I expected, but got them in!
My factory ones only come to the top of the frame rail. Easy to hose off though.I think I like those better than whatever the truck came with...seems to cover a larger area.
