Rockcrawlindude
a rock crawlin’ dude
He has a power wagon so that should be an e-lockerso thats a pic of your diff? no clutch pack config...ie a helical gear limited slip(anti-rotation)?
Hopefully redesigned for the better and not just to please the bean counters. Time will tell.I emailed AAM and Ram directly to try and find out a bit more info about what all has changed.
Based on this thread, the 2019+s underwent a fair bit of change inside the axle.
The deeper we look at the 2019s , the more it seems to be a much more thorough redesign than people have given it credit as. It’s certainly more than just a new front clip and interior.
yes mine and a pw.so thats a pic of your diff? no clutch pack config...ie a helical gear limited slip(anti-rotation)?
Aye.Hopefully redesigned for the better and not just to please the bean counters. Time will tell.
What’re you gonna do with a bunch of axle shafts after you look em over? Lol. Hey you could cut one down and make yourself a spare tire mountAye.
Clutch Plate LSD is probably substantially cheaper than Gear type.
However the larger, 32 spline pinion and different axles I’m hoping is and improvement.
I’m half tempted to buy a 2018 axle, 2019 regular axle, and 2019 power wagon axle to compare. Anyone want to help fund this endeavor?
2019+:
2018:
Return them ideally. Because what am I going to do with 3 different about shafts, only one useful for my truck lolWhat’re you gonna do with a bunch of axle shafts after you look em over? Lol. Hey you could cut one down and make yourself a spare tire mount
Doh. you’re right.Return them ideally.
it’sa full float axle so making a spare tire mount from the axle flange won’t work lol.
2020, rear - torsen ls differential, front - openSomeone needs to pop a drain plug and take a peek inside. From the reading I had done prior to ordering my RAM there was a gear driving LSD up until 2018. The 2019 and newer are using a clutch pack again.
In for rear end picsAny pictures of your rear?
Yea thats a PW locking diff.... them PW owners and flashing their lockers!@eldedo i see duratracs and looks like two wires in the diff is this a power wagon?
how much gear oil does our rearend take?
also amsoil says 75/140, redline says 75/85?
