I do for this reason.keep things from sliding around
sure it is called do it yourself with a box cutter.Do they make any with cutouts for the 5th wheel and gooseneck mounts?
I just roll it up under my toolbox when I need to use the gooseneck or 5th wheel hitchDo they make any with cutouts for the 5th wheel and gooseneck mounts?
The bed liner I have , insulation boxes barley move on that liner .Hmm interesting thoughts about adding a mat to keeping things from rolling around, or a flatter/softer layer for camping!
I certainly don’t think it’s needed for “extra protection” however. Good Spray-in liners(eg LineX, Bullet, etc) are tough as hell, even shoveling gravel out they barely get nicked, and even then just where the flat spots for gooseneck cutouts would be.
That is funny you said that because when I read that first sentence I was thinking "that will cost more than a mat!". That is a great idea though. My dad always has an old sheet of plywood in the back of his truck and it is really nice for when you get dirt or gravel because you can shovel it out easy since it is flat. Plus, he has a drop in bed liner under it so it slides easily and makes loading things easy because you can pull it out halfway so it is hanging over the tailgate, set the couch or chair or other big thing on top of it, and then just slide it back in. Maybe I will get a mat for general use so things don't slide and a piece of plywood for getting dirt and stuff.I keep a sheet of 3/4" plywood in the bed since my 2017 RAM bed with the OEM spray liner had dings and dents all over it. I carry a skid steer grapple and parts for equipment at times, and it's not that hard to ding the bed floor or the wheel well humps while placing or transporting heavy steel objects. A sheet of 3/4" plywood not only prevents most of that (assuming that I ratchet strap the item so that it does not shift), but it also lets all who see that I am soooo freaking rich that I can toss plywood sheets around as disposable objects as if they aren't worth half of the truck value![]()
