ramman2020
Looking for black badges for.2021 ram.2500 and black headlights led
Can you send pictures and price to [email protected]I have a set. New in boxes. They are the Night ED LED reflectors (BLK). Right headlamp upper bracket broke off. I bought it that way for a discounted price. I was told it still will mount with no issue, but haven't tried. Left is perfect. I think shipping will be a good bit depending on your location. I sold my Tradesman I was going to put the headlamps on. I also have a set of the LED rear Night ED taillights. I removed the taillights before I sold it. They have a few thousand miles of use, but no damage or scratches. Im in 85616. Let me know if you're interested.
Sent from my LG-US701 using Tapatalk
I'll get you pics next week. Currently out of town. Do you currently have a 2500 with the LED headlamps? If not and you have the halogens you will need the adapter harness. I'll sell the headlights for $850 for the set. The harnesses for both headlights will be $250. The taillights I will sell for $625 for the set. If you don't currently have LED tail lights you will need the harnesses for those as well. I'll sell both harnesses for $75.Can you send pictures and price to [email protected]
Hmm...I don't think it can be done with Alfa OBD. The harness and pins are different on the non-LED trucks if I'm not mistaken. Plus it needs the resistors incorporated into them. I bought them from Retroshop.us
5G Ram 2500/3500 HD (19-24) Halogen to LED Headlight Adapter (PAIR)
Plug n play harness for the 2019-2024 Ram 2500/3500 HD halogen to LED headlights - will allow you to easily add the OEM LED lights to your 19+ Ram HD! This is for a set (PAIR) of adapters and wiring harness. Please note, there are 2 versions:Reflector LED - these are the lights found on Laramie...retroshop.us
Do you need the rears? This is the adapter cable for them.
5G Ram HD (19-24) Incandescent Tail to LED Tail Adapter
PRODUCT COMPATIBILITY - THIS PRODUCT IS DESIGNED, TESTED AND CONFIRMED TO WORK WITH OEM TAILS ONLY. USE WITH AFTERMARKET TAILS - THERE IS NO WARRANTY OR GUARANTEE THEY WILL WORK. (Some 19-23 aftermarket tails are causing hyperflashing or full turn signal failures. This is not due to the...retroshop.us
That's great then. I was informed differently. I bought those harnesses thinking they were needed. Of course never installed.
