I will be going back to Ford if Ram doesn't address the CP4 soon!
Well, we know they do not suffer from the same roller design defect and fuel flow issue (no separation). We also don't have (to my knowledge) failures of them reported, and they've now been out for a while - long enough that failures would have been reported in the CP4. From everything I've read, it's a CP3 essentially clocked to a higher pressure. So my thought process was that getting back what I paid for my '20 and eliminating some known design issues was a better situation even if I had to pay a little more for the '21 (Laramie vs Bighorn) and the new pump hasn't been out as along.It. My thoughts are, the 21's, while looking like a CP3, aren't exactly a CP3, so they have no track record.
I don't know why you guys keep saying that you're going to go to Ford. They're still running a cp4. I think that pretty well makes no sense to me. I owned an lml duramax years ago so I've been over and through the cp4 thing. The cp4 is frustrating but I knew that when I bought my truck. I factored 2700 for a swap into what I was paying. If the warranty is getting close and still no service bulletin, I'll just do the swap.Well, we know they do not suffer from the same roller design defect and fuel flow issue (no separation). We also don't have (to my knowledge) failures of them reported, and they've now been out for a while - long enough that failures would have been reported in the CP4. From everything I've read, it's a CP3 essentially clocked to a higher pressure. So my thought process was that getting back what I paid for my '20 and eliminating some known design issues was a better situation even if I had to pay a little more for the '21 (Laramie vs Bighorn) and the new pump hasn't been out as along.
The equation is different for everyone and our tolerance for this type of failure is pretty low. The one thing that is not different for everyone is that FCA should never have put us in this position to begin with. Given how I think owners have been treated so far, rest assured I'll be looking harder at Ford and Chevy for my next truck - and will not be considering an FCA vehicle for a secondary vehicle (which we'll be replacing in 18 months). FCA has lost my confidence and forced me to make the best of a bad situation.
how is it “overdriven” ram runs it at a much lower pressure than ford also the ford failures are much more frequent local ford dealer techs i know say they see them in for pumps at least one a month and the 4 local ram dealers have not seen one fail yetFor the kagillionth time, the issue that makes the RAM CP4 worse is the over-driven nature and far, far higher (anecdotally through the net/forums) failure rate likely due to it.
It's a bad design for everyone. It's a very bad design for RAM.
What are you talking about? When did I say I "was going to Ford"? Beyond that, the CP4 issue is not the same for them as mentioned by previous posts..I don't know why you guys keep saying that you're going to go to Ford. They're still running a cp4. I think that pretty well makes no sense to me. I owned an lml duramax years ago so I've been over and through the cp4 thing. The cp4 is frustrating but I knew that when I bought my truck. I factored 2700 for a swap into what I was paying. If the warranty is getting close and still no service bulletin, I'll just do the swap.
That is very interesting in that it is completely the opposite in this area. My dealer is relatively small, and has had 2 failures. Keep in mind that many of their HD sales are from distant areas, so it's only local customers being serviced by them typically. The Ford dealership I have contacts with is a much larger dealership that handles a ton of fleet and commercial sales - probably 100 times larger than my RAM dealer. They claim to have less impact from the CP4. But who really knows since there is no concrete data to read. Like Epsilon said, it's a bad design for everyone, but a worse design for RAM owners due to their specific modification.how is it “overdriven” ram runs it at a much lower pressure than ford also the ford failures are much more frequent local ford dealer techs i know say they see them in for pumps at least one a month and the 4 local ram dealers have not seen one fail yet
"rest assured I'll be looking harder at Ford and Chevy for my next truck"What are you talking about? When did I say I "was going to Ford"? Beyond that, the CP4 issue is not the same for them as mentioned by previous posts..
And beyond that, we have ALREADY discussed AT LENGTH the fact that factoring in the $3k for the swap does not even come close to leveling out the issue. First of all, if you do it proactively, you just killed your warranty. If you DON'T do it proactively and it fails, you're down 3 months and then have to do the swap. Unless you're going to pay out of your pocket for all the other components such as injectors, etc. And beyond THAT, if you're pulling livestock, how exactly does that resolve the sitting on the side of the road with a gooseneck trailer full of livestock in the middle of nowhere, potentially 15 hours from home?
Word on the street is that we may hear something this month. There is a warranty bulletin posted from NHTSA that someone posted on another group/forum (https://static.nhtsa.gov/odi/tsbs/2020/MC-10184746-9999.pdf), I assume it's legit only due to the fact of the URL where it's hosted. I'm not familiar with the fast feedback program but my guess is they may issue a recall post this. @RamCares has already made comments about a service solution, however they have not yet responded. My guess, and it's strictly a guess, is if they are going to announce something it will be June/July timeframe.What can actually be done to put pressure on RAM? We see recalls from other manufacturer for other defects that can leave you in a difficult/dangerous situation. But nothing from RAM yet.
Beside the two random messages from @RamCares, it doesn't seems like something is going to happen.
Do we need a class action? Is that what it will come to?
Thanks for the update.Word on the street is that we may hear something this month. There is a warranty bulletin posted from NHTSA that someone posted on another group/forum (https://static.nhtsa.gov/odi/tsbs/2020/MC-10184746-9999.pdf), I assume it's legit only due to the fact of the URL where it's hosted. I'm not familiar with the fast feedback program but my guess is they may issue a recall post this. @RamCares has already made comments about a service solution, however they have not yet responded. My guess, and it's strictly a guess, is if they are going to announce something it will be June/July timeframe.
In terms of putting pressure, I think the only thing you can do would be to file complaints with RAM and on NHTSA by reporting a problem. Beyond that we are at the mercy of FCA and their decided timelines. My hope is they are doing the work to build stock and get a recall plan in place, so that when the recall is announced they will have the stock to actually do something. Keep in mind that COVID has absolutely wrecked global shipping and manufacturing systems so that could be a large part to the delay.
A: That was posted here a long time ago.I just cant believe another group would post something before this one. What's going on here?
That or a factory recall conversion kit FCA is using on failed CP4 vehicles...At least maybe I could keep my warranty.I agree, pretty much the same thing for me. I looked in alberta and everything is selling for 5K off MSRP. Didn't make much sense.
Hopefully a repair recall announcement comes very soon and replacement with the ISB21.
The dealer in Wickenburg had 6-10 of them on the lot when I passed by Monday morning.I don't feel this is the time or place to buy a truck with what all is going on. Here in southern AZ I have not seen a dealer with more than 2 or 3 trucks on the lot.
