Epsilon Plus
I feel I picked the worst one I could have for towing.
Is this real life or the Matrix?
That ISB 6.7 punches so far above it's weight class its unreal. Your 1500 5.3 "towing capacity" is a sham. The SAE Davis Dam test they use for those phoney ass numbers is perfect dry weather, no heavy winds, no panic stops with a low profile deck trailer with some pallets of bricks on it. I had the 2016 version of that truck. my 11x33ft measly 7,600lb GVWR travel trailer tossed that truck around like a dog with a chew tow on flat, dry, freeways with no wind and cross traffic.
MPG will improve as the engine breaks in, but MPG and low running costs are not a good metric for why you buy a 850lb/ft modern emissions saddled diesel.
Now that I've repeated everything that everyone else already said, I'll throw the match on this tinder box:
Your payload is BS. The 10k GVWR cap is a fee violation, your GAWR are 6,000/6,040 and all the DOT will care about (other than tire ratings). People will say you'll be sued for everything you own if you wreck over 10k GVWR but can't provide evidence.
Suffice to say, to the ire of the 3500 crowd, there are likely far more 2,300+lb pin weight 5ers being pulled by 2500s than by 3500s every day in this country and they handle it just fine. If you need ridiculous payload to haul crap around, get a low deck trailer or a utility trailer for a few grand and continue to enjoy those coil springs while being able to load stuff lower and haul just as much as the bed of a dually.
