295/65R20 Pics please
After about a 1,000 miles, I checked again and I’m rubbing on the radius arms. Only at full lock and not much but it is rubbing.
I just did 295 60 20’s so 65’s would fill it in even more. I think these are perfect though. And speedo is only 0.86 off at 60 since the gearing didn’t change much.
Great setup!! Yes the 295/60 measure 33.9 so 295/65 will be 35.1 will def. fill them up....also I'm getting mud flaps front and back I see you have them on the rear! Looks great
I’m running 295/60 20s on my current rims. I rub a little at full lock and even more in reverse
So toyos 295/65R20’s installed. Went to use the Hypertech speed o calibrator and didn’t work so called them and they said 2021 with all the parking sensors and such need a different part and it’s more complicated but pulling the gauges off etc. EF THAT. My Speedo is off by 1-2 MPH, mostly 1 and tranny still shifts like butter so do I really need to do anything??
I wouldn’t. I went up in tire size a similar amount on my 2008 years ago. 10+ years and 125k+ miles with no powertrain issues. Your truck wont notice the change, which is only a few % points difference.
Yeah I’m agreeing with that… I already put about 500 miles on it the only thing I notice is it takes just a marginal amount more on the skinny to get it going but hardly enough to even notice… Tranny still shifts great
Mine had 295/65 Falken at3w when I bought it on stock suspension. Was a great tire, and I thought a perfect size at stock height with zero rubbing.
Couldn’t help jumping all the way to 37x12.5 after the small level.
Good MPG is over-rated right? Ha
