That is its purposeHello, just towed my 5th wheel with my 2020 3500 dually used tow haul mode when braking it seems to use some sort of engine brake assist is the normal. I liked it, is it rough on tranny?
There is a switch on dash for exhaust brake, when you are in tow haul does it automatically applied that brake or is this something else. I didn't have exhaust brake switch on.That is its purpose
Same as Goose said, my 2020 3500 HO's tow/haul does not turn on the EB.
I run with the EB turned on all the time.
When running unloaded it is good to run the exhaust brake either full or auto. This keeps the Turbo clean and helps reduce EGR soot build-up as well. I'm told that running on auto (green light) does not affect mileage or DEF use. Full will use a little more DEF and I can't tell but some say about 1 mpg Hwy.
Calibrated tunes keep the exhaust brake on 100% of the time at whatever setting you choose.
Plus it sounds cool.
