AnthonyD1978
I hard mounted mine in the Ram box and also hard wired it with Anderson plugs so I can easily detach it if needed.
I was able to use the factory bolts that are already in the ram box and used the drain plug grommet to run the power lines out of the ram box.
Also have parts coming in to add a pressure switch and build a 4 tire inflation kit.
