Please Post Payload Sticker from Driver's Door Jamb.
Here is mine, RAM 2500 LARAMIE MEGA CAB 4X4 Off–Road Package Granite Crystal Black, Night Edition, Uconnect® 12–Inch with Navigation, 6.7L I6 Cummins Turbo Diesel Engine, 3.73 Axle Ratio, 6–Speed Automatic 68RFE Trans, Towing Technology Group , AMP Research Hide Away Passenger StepsView attachment 7324
This seems high to me which makes me happy. My truck hasn’t been built yet. Anyone else with a diesel 2500 megacab? Would a limited make this any different?
My 2500 Laramie Megacab 4x4 Cummins, Level 1, Safety, Tow packages. Payload shows as 1955# via VIN on the Ram website. I will post picture of sticker when I get the truck, hopefully this month.
Checkout this door sticker.
Ram 3500, 6.4 Hemi, 4x4, CCSB, SRW.
Laramie lv1, 5th wheel gooseneck prep, bed utility package, towing technology package. Yes I have blind spot and cross path detection.
CCC 4025 :)
I don’t have the truck yet but I do have the window sticker so I am able to put the VIN in the Ram towing and payload website to get my payload and max trailer weight.
Max payload 3759
Max trowing 20,259
Max payload 3759
Max trowing 20,259
I'm sure those numbers put a smile on your face :)
2021 3500 6.4L Hemi 4x4 8ft box SRW, Laramie level 2 with just about everything except sunroof and 12" screen. 4082lbs
That's a great door sticker. What's interesting is we have basically the same truck except yours is the 8' bed which got you an extra 57 lbs of cargo. I thought it would have been higher.
I'm actually surprised the 8ft bed didn't loose a little payload due to the added weight to the vehicle from the longer box, frame rails, etc.
a bit more payload than my 2020 1500 :D
looking back through these stickers, some of these 2500's have less payload than my 1500 had! One reason I told my wife if we get a diesel it will be at least a 3500. we are searching for a fifthwheel, looking at 2000-2500 pin weight + aux fuel + second spare tire... it adds up.
GVWR minus payload equals curb weight, correct?
So the weight of these trucks swings from 6,000 lbs. on a stripper 6.4L Tradesman all the way to 8,600 lbs. on a well equipped Cummins Limited? Holy cow.
Just the cummins alone is 500lbs heavier dry than the 6.4, the trans, axles, driveline, and accessories add up fast!
I would have lost 880lbs payload by going with the Cummins over the Hemi I ordered, the diesel is a lot heavier than most people think.
