Purchased above described truck used on 3-13-21. Drove it once approx 500 miles when the following message appeared on the dashboard. " Exhaust system service required see dealer" The truck went into safe/ limp mode as a result. I drove it to the closest dealer ( Feldman Ram in Woodhaven Mi.) who tested the truck and indicated that the low pressure fuel pump needed to be replaced. The dealer replaced the pump and had my truck ready for pick up on 3-29-21. I received the same error code upon leaving the dealer and am now told that the high pressure fuel pump needs to be replaced and the part is on back order. Fast fwd 13 days and daily calls with both Ram care and the dealer and the part has still not been ordered. I started a star case and learned it was declined pending further information from the dealer. In the process I learned that the low pressure fuel pump was replaced in December 2020 ( less than 1,000 miles ago) and that there was another star case in February 2021 for some type of computer issue.
Any thoughts or direction would be more than appreciated! I'm getting nowhere with Ramcare or the dealer.
