Aykillah
Thank you. I searched ”USB” and 3 threads came up. I wonder what I did wrong?![]()
Add USB ports to rear console
Looking to add usb charging ports to the back of the 40/20/40 bench seat between the heat vents. Right now there is a small pocket there. Anyone have OEM part number or have done this on 2019 2500 Tradesman?hdrams.com
This is awesome! Thank you. This is next on my to-do list.I'm almost finished with this mod. I'm just waiting on the factory usb harness, but confirmed that it does work with a temporary usb jumper cable.
Here's what I had before:
Here's after:
For the new face plate I ordered part no: 6QT85TX7AC - Console End Cap - $142.24. Mine came with the usb and 115VAC outlet. Otherwise the part number for the USB only outlet is 68402777AF.
Drivers seat harness to rear USB panel: 68468100AA - WIRING. Seat. Left - $86.70. XY360 connector and female usb under drivers seat to arm rest USB, rear USB and 115VAC connections for the rear outlets.
USB factory cable: 68096423AC - $24.86
Other items:
The main power line from the truck did not exist at the XY360A connector under the drivers seat. On my truck however, it was fused and existed on the PDC side of the XY125 connector under that dash. In my case, I salvaged a male pin and female pin from the old driver's seat connector and ran a new 19 awg wire between the two. It is Pin 46, red wire on the XY125 connector to Pin 1 on the XY360 connector.
The usb cable will connect to an open USB port on the hub in the center console to the new harness drivers seat harness. The power line from the XY125 connector will connect to the XY360 connector under the drivers seat as well. I did remove the center armrest/seat for easier access and cable routing.
Best of luck.
Was that USB just laying under your seat? Or did you have to find it? I want to add the factory USB ports to the rear center console.Anyone know if it’s possible to use this harness to add a USB outlet to the rear where I circled? I tried searching but didn’t come up with anything.
Yea it was just laying under the drivers side seat. Shouldn’t be too hard to find.Was that USB just laying under your seat? Or did you have to find it? I want to add the factory USB ports to the rear center console.
Hmm was it under the carpeting or anything? I have a bighorn with the center console and I can’t find that USB. I would love to add the factory USB to the rear of the console.Yea it was just laying under the drivers side seat. Shouldn’t be too hard to find.
No it was right on top in plain view.Hmm was it under the carpeting or anything? I have a bighorn with the center console and I can’t find that USB. I would love to add the factory USB to the rear of the console.
Oh maybe.I have this in the center console. I wonder if it’s different since you have the jump seat?
Did your jump seat have any USB ports in it?Oh maybe.
No ports in my jump seat.Did your jump seat have any USB ports in it?
I just walked through the lot I bought mine from. All of the 2021s with jump seat have a usb plug in the center console, not the rear just under the lid. I wonder if that’s why mine doesn’t have this usb. Also the usb in my console does not activate the CarPlay feature.No ports in my jump seat.
I had to run a USB jumper cable from the back of the USB port on the lower part of the dash, under the carpet to the new USB port for the 2nd row. I ordered part no: 68096423AC.No ports in my jump seat.
So you used the above wiring to complete the pictured after correct? We’re there any unused plugs? I’m wanting to add that USB and outlet along with the rear seat heaters. I found this wiring 52112462AD, but I’m not sure if it would work or not. That one is listed as console wiring where as yours says seating wiring.I'm almost finished with this mod. I'm just waiting on the factory usb harness, but confirmed that it does work with a temporary usb jumper cable.
Here's after:
Other items:
Best of luck.
