This is the one I ordered, but I assume any of the competing products would work the same.
https://www.amazon.com/Compatible-2...14087604&rnid=2941120011&s=automotive&sr=1-68
And yes, there are two screws and two plugs to disconnect. The replacement will only have the one plug (no camera connection).
The camera itself can be removed from the stock light if you want. I wrapped mine in a little plastic, reconnected it via the plug and then tucked it into the headliner behind the new replacement. But I assume you could also simply leave it unplugged.
