smileshapr
Hello Fellow RAM owners. I am new to this site but I am on my third RAM truck. The first was a 1500 in 1998. The second was a 2007 Power Wagon that was AWESOME!!! but unfortunately exploded its transfer case at 70 MPH on Interstate 81 in PA doing enough damage to total the truck. I am now the VERY DISAPPOINTED owner of a 2020 Power Wagon due to its AWFUL performance in wet snow 6-8 inches deep. This truck has wheel hop /axle wrap so bad you cant go anywhere. On 3 occasions this winter I have been EMBARRASSED by being unable to climb small hills in 4lo and locked axles only to have a stock 2014 F150 go around me. Tried 4 Hi with no success and unbelievable bouncing unable to achieve traction. Pulled cable on one of the outings but was able to back out on the other 2. I even aired down to 25 psi which helped a little but still could not make the hills that a stock F150 with all terrain tires can make with no lockers. Is anyone else having this problem? RAM seems to know about this issue because when I complained at the Dealer, I was told others have mentioned the bouncing. Also, the 5th shock tells me they knew about the issue and put a band-aid on it. I'm a little disgusted that I bought a truck that is supposed to be best in class off-road and it is EMBARRASSING!!!! This design should be recalled and fixed by the company! Any help would be appreciated.
