Is the 4.10 the way to go with one of these? Will there be any disadvantage to it besides MPG, and is that even going to make that much difference?Definitely more diesels on the lots. I had been wanting a 6.4 with 4.10 gears, but they are as rare as hens teeth around here. Stumbled across mine at my local dealer and jumped on it immediately. He said he wished he had more of this set up, because the demand is high.
While the standard 3.73 is fine for everyday non towing, the 4.10 is IMHO the way to go. MPG is the only disadvantage and thats only by a 1 or 2 MPG depending on how you drive. The 4.10 tows like a beast and is very peppy off the line when not towing.Is the 4.10 the way to go with one of these? Will there be any disadvantage to it besides MPG, and is that even going to make that much difference?
Anyone have a link to 3/4 and 1 ton percentage of sales...gas vs diesel??? Around here, I seem to see more gassers on the lots.
Approximately 75% of all RAM 2500 and 3500 Heavy-Duty pickup owners choose the optional Cummins Turbo Diesel.
Take rate on the diesel in 2500/3500 Ram HD is 75% according to Cummins:
Having owned both, it is by far the bestIs the 4.10 the way to go with one of these? Will there be any disadvantage to it besides MPG, and is that even going to make that much difference?
Both 8 speeds?Having owned both, it is by far the best
Yes for the small mpg penalty 4:10 if your gonna towHaving owned both, it is by far the best
3.73 with 6 speedBoth 8 speeds?
3.73 to 4.10 is like, 150 RPM on the highway. You can't even see that on the tach, nor can you detect any difference in drivability whatsoever. To me it's laughable that Ram even offers those two ratios.
I can sort of understand the 3.21 vs. 3.92 options in the 1500....there is enough difference there that it actually matters depending on intended useage of the truck. But 3.73 to 4.10? What a waste of time.
Over the last few decades I've done a lot of ring and pinion swaps and to me, I always had to go at least two "sizes" up if not three to be able to detect any real difference in performance or fuel economy. So, 3.73 to 4.56 would be ok but 4.88 would be better. That type of thing. Going to 4.10s to me was always a waste.
