What are the different types of instrument clusters?
jm888
I have seen pictures online where it appears the info display screen in the instrument panel between the gauges looks different. Are there two different sizes and if so, is that determined by the trim level or one of the options? Or are there 3? I see a 3.5 screen listed on some window stickers but is there a bigger one?
Standard cluster is 3.5"
You can get a 7" EVIC by adding the "Safety Group" to a Tradesman.
The higher trims also have a 7" "EVIC" depending on options or standard features.
Oh ok, I see it now. Do you know if it can be added to a Big Horn? I couldn't find it in any of the options. And can you get more information on one than the other, or is it worth it?
Weird, it should be in the Level B (was Level 2) package but it's not showing. The change from Level2 to Level B might be causing an issue or it's not showing correctly. If you're serious about an option on a truck, contact the dealer.
As Brutal stated, it is part of the Safety Group on any trim from Tradesman to the top. My buddies Tradesman has it and I have it on my Big Horn. Reason likely being that the graphics and info needed to be displayed by all the safety systems wouldn't work on the smaller screen or they didn't want to have to make a bunch of versions.
The 7" fully configurable screen is the only way to go. It's one of the best parts of the 2019+ Ram HDs. Don't order without it!
7" color is ordered on my Big Horn, night edition, level 2, off road....
Might it have something to do with the off road package? Hill descent and the info pages are listed on off road with 7" color display.
It is listed on my window sticker under Level B group, Big Horn.
So you actually got this with the Level B after it changed from 2? That would make sense, since I was able to add it to a Tradesman. It is weird because the Level 1 Group shows a 3.5 color display and under the Level B it doesn't mention anything about it but is $2525 more and only includes a 115 volt outlet, dual zone temp controls, heated front seat and steering wheel, LED tail lamps, and parksense. Doesn't seem like that much for an extra $2525. I didn't see the 7 inch under safety group either. Maybe this is a mistake and it would get added when the dealer inputs it because I can't imagine being able to get this on a Tradesman and not a Big Horn. It is probably needed for some of the safety features anyways, right?
