Hi all, I'm hoping to get some input on a new 3500 CCLB SRW build. We will primarily be using it to haul a slide-in truck camper and may possibly tow a Jeep at the same time. We will be upgrading from a 2016 Ram 2500 CCSB with G56 transmission as the coil suspension on the 2500's just doesn't cut it with our high center of gravity load and we also want the 8' bed. We live in CO and will be using it in high elevation mountainous terrain (think Ike Gauntlet every weekend) so I would prefer a diesel even though the truck camper is not all that heavy (~2500 pounds total load).
We had a good experience with our '16 but are not particularly brand loyal so are also considering an F350. Solid front axle is important to us, so we're not considering GM.
If we went Ram, we'd consider either Big Horn or Laramie trims and would look for these options:
-50 gallon tank
-5th wheel prep for extra plug in bed
-Snow chief package
-LED headlights
-Bed utility group
-Towing tech package
Love to hear if there are other recommended options that we've overlooked. Some questions that we have are:
-What's the consensus on the value of the adaptive steering system? Any issues using it offroad with larger tires?
-SO vs HO for truck camper uses? Our '16 Cummins with the G56 was agonizingly slow and suffered from a lot of dead pedal/torque management, however I do enjoy picking my gears and sensing exactly what's going on with the transmission. I ended up doing an emissions intact tune from CPS to make it more driveable, but would prefer to be able to leave this truck unmolested. I understand the 68RFE has better manners unloaded while the Aisin shines when towing, but am not sure if a truck camper is enough of a load for the Aisin to come into it's own?
-Compelling reasons to pick Ram 3500 vs F350 with equivalent options? Ram has gone back to the CP3 pump for 2021 which is great, and the turn radius on the Ram is much better than the Ford, however the 10 speed and 475hp in the F350 is pretty tempting.
Thanks for your input!
-50 gallon tank
-Snow chief package
-LED headlights
-Bed utility group
