Supergumby5000
I finally pulled the trigger on the lift for my truck. Based on availability and what manufacturers offer for the 3500 dually, I ended up ordering my own kit a la carte with a combination of manufacturers. I've ran into a road block though - I cant seem to find sway bar drop brackets that can be purchased separate from a kit for the 2019+ HDs.
The only vendor I've found who sells them separate is Carli.... I am having a little bit of a hard time stomaching the $125+ for two metal spacers (especially when I've found PLENTY of options for the pre 2012 rams around $50/ea.
Can anyone help point me in the right direction on where I might be able to order these as individual parts? I wonder if I call someone like BDS or readylift if they would sell the parts separately. It doesnt appear that you can order them loose on their website (that, or I cant find them in the parts menus).
And for those who were curious about my piecemeal kit:
-Carli 3" coils
-Carli radius arm drop brackets
-Thuren tuned Fox IFP shocks
-Rough Country Track Bar
-1.5" rear universal blocks & replacement u-bolts (RC u bolts, pro comp blocks was the best combo/option at the time)
-BDS bump stops for correct lift height
-Still trying to find sway bar brackets
For what its worth, I'm coming in about $400-$500 cheaper (pending the brackets and bump stops) than buying a packaged kit containing similar components and I (hopefully) shouldn't be on a 6 week backorder (current wait time for the Commuter kit).
-Carli 3" coils
