last thrusday on the way to the cabin while towing my single axle trl loaded with lawn tractor, i was getting on rt 322 w, started to accelerate up the ramp, 18 whlr moved over but jack ass in other lane cut inside him to slow lane, i floored it to outrun him, the gas pedal stuck wide open, 40mph to 85 mph does not take long with this trk, when i realized the pedal was stuck i hit the brakes hard and the dash lit up saying the Electronic Throttle Control had failed and would go to service mode, the pedal did not feel freed up so i put my toe under the gas pedal and pulled back on it, i heard a snap, like a broken branch or something and all seemed well again, looked in the "messages center" and nothing there .... have driven it almost 400 miles since then and all seems to be operating ok .... i don't think i will take it to the dealer just for them to tell me they can not reproduce the problem .... anybody else have a similar problem??
EDIT: on page 184 of the Ram manual it says this ....
— Electronic Throttle Control (ETC) Warning Light
This warning light will illuminate to indicate a problem with the Electronic Throttle Control (ETC) system. If a problem is detected while the vehicle is running, the light will either stay on or flash depending on the nature of the problem. Cycle the ignition when the vehicle is safely and completely stopped and the transmission is placed in the PARK position. The light should turn off. If the light remains on with the vehicle running, your vehicle will usually be drivable; however, see an authorized dealer for service as soon as possible.
NOTE: This light may turn on if the accelerator and brake pedals are pressed at the same time. If the light continues to flash when the vehicle is running, immediate service is required and you may experience
reduced performance, an elevated/rough idle, or engine stall and your vehicle may require towing. The light will come on when the ignition is placed in the ON/RUN or ACC/ON/RUN position and remain on briefly as a bulb check. If the light does not come on during starting, have the system checked by an authorized dealer.
