I have been using the Banks PedalMonster with my 2019 3500 HO for the last 13,000 miles. I ordered one the day they became available for this truck.
As others have said, the PedalMonster just changes the pedal mapping (position and velocity). When you push the pedal, it acts like a man-in-the-middle and remaps the actual pedal position and velocity. It tricks the truck into thinking you pushed the pedal farther or faster, depending on the settings in the PedalMonster.
While this not the same as an engine tune, the net effect is that the truck feels much more responsive. If I think "go," the truck goes. I don't have to put extra muscular effort into "go" which tricks my brain into thinking the truck is faster when in reality it would behave the same if I just pushed the pedal farther and faster.
I like that it doesn't change any of the engine parameters because it has much less chance of voiding a warranty. It leaves no trace when uninstalled.
Yes, it is a just a throttle trick, but it makes me giggle every time I barely push the pedal and the truck takes off, so the money was well spent. I understand that quickly accelerating will wear out the engine, transmission, etc. more quickly than stock, and I accept that.
My main complaints are:
1. Sometimes it "forgets" that I have a Ram 6.7L engine configured, so I lose the transmission gear value which is one I monitor on the screen. Changing the engine setting fixes it. I have reported this to Banks, but they haven't reproduced the problem. It has happened 3 times in the last year.
2. Twice, the PedalMonster has silently stopped remapping the throttle position. I can tell when it happens because I have to push the pedal harder. Both times, the fix was to unplug the PedalMonster from the OBD-II port as restarting the truck didn't reboot the device. I don't consider this a safety issue because the device just reverted to factory throttle mapping which is what Banks claims is one of the distinguishing features of their product compared to competitors.
3. It is very expensive because you have to also buy a Banks iDash. I ended up really liking my Banks iDash, so I feel like I got my money's worth, but if you don't care about the iDash then you won't be happy with the price.
I take it the iDash is required to make adjustments?
www.bankspower.com
My petal monster is a stand-alone..you download the app and us your phone to change the settingsI just looked at the Banks web site. It looks like they now sell a standalone PedalMonster that works with the Ram 3500. You aren't required to buy the iDash if you don't want those features.
PedalMonster [64310] for many Cadillac, Chevy/GMC, Chrysler, Dodge/Ram, Ford, Jeep, Lincoln, Mazda
#1 Throttle Booster. Patented safety features. Bluetooth mobile app controlled. OBD-II connected. Improve pedal response for Chevy, GMC, Dodge, RAM, Jeep, Ford.www.bankspower.com
Call it what you want, it is a real issue and is dangerous under certain circumstances.It’s the torque management that is causing what you call dead petal..
I am just guessing they dont like to smash the skinny pedal or are to short to stick it to the floor.... if i want it to go i just mash the pedal and it goes... if i want to eliminate the tq delay from tq managment i just use the gear limiter to 5 and get all the power right away then back to 6th gear once the needle gets close to the ketchup (redline) or at the upper limits of that gear....My 2020 / 3500 Mega Cab HO has never had any sort of bad pedal management issue what so ever. I give it fuel and it goes and pulls like it should.
No, coming from a 2500 with a 6.4 that thing when you would push the pedal it went no matter what. I would floor it and it would go right now. I just traded that in for a 2020 3500 HO and if you don't roll into the throttle it does not want to go. If you pull out into traffic and floor it you can count to 2 or 3 before the truck really takes off. That's not even taking into account what people were talking about where you get in and out of the pedal quick and then get back into it. It will stumble and fall on its face for what seems like forever then. So no it is people are "afraid to press the pedal"I am just guessing they dont like to smash the skinny pedal or are to short to stick it to the floor.... if i want it to go i just mash the pedal and it goes... if i want to eliminate the tq delay from tq managment i just use the gear limiter to 5 and get all the power right away then back to 6th gear once the needle gets close to the ketchup (redline) or at the upper limits of that gear....
Something has to be wrong with your truck as mine, a 3500 HO when you step on the pedal it goes just as my 16/ 3500 did.No, coming from a 2500 with a 6.4 that thing when you would push the pedal it went no matter what. I would floor it and it would go right now. I just traded that in for a 2020 3500 HO and if you don't roll into the throttle it does not want to go. If you pull out into traffic and floor it you can count to 2 or 3 before the truck really takes off. That's not even taking into account what people were talking about where you get in and out of the pedal quick and then get back into it. It will stumble and fall on its face for what seems like forever then. So no it is people are "afraid to press the pedal"
You cant compare gas and diesel throttle response and thats torque management.... i have the SO cummins but i have driven a few HO cummins with no issue of what your describing but i keep on the pedal no on and offNo, coming from a 2500 with a 6.4 that thing when you would push the pedal it went no matter what. I would floor it and it would go right now. I just traded that in for a 2020 3500 HO and if you don't roll into the throttle it does not want to go. If you pull out into traffic and floor it you can count to 2 or 3 before the truck really takes off. That's not even taking into account what people were talking about where you get in and out of the pedal quick and then get back into it. It will stumble and fall on its face for what seems like forever then. So no it is people are "afraid to press the pedal"
Accurate.You cant compare gas and diesel throttle response and thats torque management.... i have the SO cummins but i have driven a few HO cummins with no issue of what your describing but i keep on the pedal no on and off
YesSorry Mike, want to make sure I understand. So even with the Pedal Commander, it still has a lag when accelerating while under power? (i.e. Passing?). However it is great from a standing start?
I will try that!Hmm, as a temp work around can we manually shift down and then floor it? (Not a good work around but just curious). Wish I was driving right now to test instead of behind a desk lol.
Yes precisely!Usually I get the dead pedal if indecisive when turning across traffic, for instance. A quick on the throttle , off the throttle, on the throttle and you’ll enjoy the dead pedal.
Yeah, in today’s age when computers are considered to be fast and up your productivity, makes me wonder why this is even an issue but it is.I have experienced the dead pedal once in my 3500 HO - unloaded - when I was trying to change lanes....let off the pedal slightly to look then when I went to move in the lane the pedal seemed go down but no pick up in speed....it does make you a little nervous for a split second.
After the AUX Fuel tank this will probably be my next purchase.
You got the unicorn like the 200mpg carburetor.I have yet to experience this and based on what has been said I've tried to replicate it. It responds exactly as it should when I hit the pedal.
