They replied to this very thread on page 1...
Oops, however that was still back in December, and we haven't heard anything since we discovered this issue in the logs.
So today i decided to go take some readings with our FDA Certified IR thermometer to see what the truck would output manually set to MAX A/C. The truck was at Operating temperature 188, and the Outside temperature is 72. Keep in mind my truck has a SINGLE zone AC unit.
Infrared thermometer can give a general reading and are good in some cases. For example, a return air that is high up can get a quick general reading.
Infrared thermometer don’t work well with copper lines which scatters the infrared sensor.
Again manufactures may have some good ones out there (I haven’t tested them all) but in my experience infrared is only good to get generalized readings.
Hello.I think every time the truck is started, it monitors the cabin temperature continuously throughout the drive and adjusts the temperature accordingly. For example, I get in the truck, it's 58 degrees out, i have the temp set at 70, so the truck thinks the cabin temperature is 70, and it knows the outside temp is 58. So the truck blows luke warm air to maintain 70, but of course you start driving the suns out, and that luke warm air quickly makes it too warm in the truck, i change the temp to 68, now the truck thinks the cabin temperature has just dropped from 70 to 68, so it starts blowing MORE heat, so i turn the temp down to 64, truck thinks the cabin temperature just went from 68 to 64, the truck thinks is getting much colder, so it blows pretty much maximum heat at me.
I force the the temperature to LO, according to the logs, the truck is now seeing 0 degrees in the cabin, however some other piece of programming sees the LO setting and overrides the climate control logic and gives me cold air. I leave it for a minute, then slowly start working the temp back up, now i set the temp back to 64, so the truck sees the in cabin temperature spike from 0 to 64, and now gives me cool air because it sees the temperature is quickly rising, and continues to give me cool air up to 68 - 70 degrees depending on the outside temperature.
What i find super curious is the vent door control & fan speed seem to work correctly, if i turn the temperature setting down it changes the air flow to the dash vents as it's supposed to and it increases fan speed, but the temperature control gives me heat instead of cool air. And i've seen on the few hot days we've had so far, if i push the temperature UP, the vent control changes to foot vents and defroster and the fan speed goes up, but it continues to give me cool air.
It's almost like the Uconnect has control of the Vent Position and Fan speed, but the Climate module is doing it's own thing with the temperature based on the wonky data it's seeing from the false cabin sensor data.
Yea, Toyota could call it the One Tundra. I sent them an email a few years ago.If the Japanese decide to break into the HD market, (and they will eventually) the big 3 will get another rude awakening.
I am hoping TSB 24-001-20 may fix it. My truck is scheduled to get serviced next week. I will report back afterwards.
Hi @thestuarts and @Cseybert, we are sorry to hear about the trouble that this may be causing you! Please see below for the attached TSB #24-001-20. To ensure this TSB applies, we would like to get you back into the dealer to have a qualified technician review the details of the TSB and specifics of your vehicle. Once reviewed, the technician can then perform the repair procedure that best matches the symptoms and diagnosis of your vehicle. Please send our team a private message for additional support throughout your dealer service if needed!Yea, Toyota could call it the One Tundra. I sent them an email a few years ago.
Yes, the tsb should fix the issue. Have yet to hear of anyone on the forums having the repair done though. I assume most, like myself are waiting on parts.Without reading this whole thread, it there a possibility this SB will fix the heat and the A/C issue?I believe I have both. Poor performing A/C and I'm constantly adjusting the heat in the winter.
Kathryn
Ram Cares
@g00fy,@thestuarts very very interested to see if the set points and data are now correct in the system, please post asap!
@g00fy,
Today I had time to test the set points. I am getting the same senor results as before the repair:
1. The Cabin temperature sensor value always mirrors the ATC Set-Point Right Temperature.
2. The ATC Set-Point Left Temperature is always blank.
I am using the latest version of AlfaOBD for Android. I tried using the latest version for the PC, but for some reason these sensor values are no longer available in the Climate Control data logging.
I did notice a new behavior with the latest AlfaOBD; it says I need to use a "MS-CAN BLUE Adapter" which I don't have.
Here are the possibilities, as I see them:
1. AlfaOBD needs the MS-CAN Blue adapter to properly read the sensors, but I don't have the adapter.
2. AlfaOBD doesn't really need the MS-CAN Blue adapter, but it is reading the wrong values from the CAN bus.
3. There is still a bug in the new version of the HVAC module (or somewhere else).
Here is a picture of the HVAC set to max low. Notice the Cabin temperature is reading 0 degrees Celsius (which it isn't), and the Left ATC Set-Point Temperature is blank.
Here is a picture of the HVAC set to max high. Notice the Cabin temperature is reading 126 degrees Celsius (which it isn't), and the Left ATC Set-Point Temperature is blank.
Here is AlfaOBD telling me I need the MS-CAN Blue adapter.
Well, data values aside, does the climate control actually behave better now? As long as it works better then who cares what the logs say lol.
