Thanks!!I absolutely love the Gatorback Mud Flaps. Superb quality stuff. Heavy duty rubber.
No metal drilling. But some holes will be needed in the plastic tub. The rears comes with a bracket that solidly fix the flaps to frame.
The following link is the pre-made kits:
Truck Hardware - Custom Fit - Mud Flaps & Accessories
www.truckhardware.ca
I recommend the 21in wide over the 19in even with stock shoes.
I'm not sure if it will come with them...So does your dealer not supply mud flaps as part of the purchase? In Texas, all DRW trucks are required to be sold with mud flaps already installed.
Pretty much all commercially available options have been discussed above.I'm in the same situation as the OP. But want them lower to the ground on stock height truck.
Both, your dually flares will get hammered if u don't.Do you guys run mud flaps on the front and rear or just the rear?
