2018 winch question
beachbunny
on my 18,i've got the warn 12000 # winch. it carries 7/16 cable. after lugging that around a few times,i'd like to switch to synthetic, warn says i cannot.
anyone have any input on this one?
cable gets heavy .
tia
cable gets heavy .
tia
Did they give you a reason? There are lots of manufactures that make 12k synthetic line
My 2019 has synthetic. And I switched to synthetic on my Jeep. You'll have to switch the fairlead out for a haws fairlead.
Sent from my Pixel 2 XL using Tapatalk
Roller fairleads are fine with synthetic (actually better, since they roll they don’t build up heat/abrade the synthetic line) HOWEVER you definitely need to replace the fairlead if it’s been used with steel cable because it may have burrs/rough surface. Also need to make sure the gaps between the rollers don’t allow the rope to get pinched.
I have the OEM hawse fairlead on my 2019, but am looking to replace it with a roller fairlead. If not pulling straight on, the rope wears against the fairlead substantially, and the powdercoat is pretty abrasive.
@OP, use either “the grabber” by bubba rope, or this knot to attach synthetic to the drum.
All of this is true ^
you want to make sure the fairlead and the drum are free of burrs or jagged bits.
my Toyota is fitted with a warn that came with steel cable and a cast iron hawse fairlead (I loathe roller farleads)
The steel cable dug into the hawse fairlead a little bit but despite looking rough it it’s smooth to the touch. I can rub my fingers all over it and nothing is sharp or jagged. You want to make sure you aren’t going to shred your rope.
If your drum or fairlead are rough you can just sand them down
Here is a pic of the cast iron fairlead that has some wear from steel cable but is being used with synthetic line
Warn synthetic line has a eyelet loop on the drum end and you have to install a little knob and put the loop around the knob.
When I purchased replacement synthetic rope for my warn that came with steel cable that is fitted on my Toyota, I purchased from tactical recovery equipment.
their synthetic line had a steel thimble at the drum end and attached the same way as the steel cable it replaced as @H3LZSN1P3R mentioned.
To clarify, i assume the guy at warn was speaking about their spydura line which attaches, as I posted above, with a spliced rope eyelet.
Aftermarket synthetic lines I’ve seen attach with the thimble. They’re made to replace steel cable.
What do you loath about roller fairleads? I have had great luck with them... i have a hawse fairlead for my m8000 warn winch on my flat deck trailer though gonna try it out
Mostly the fact that they can and do fail. Hawse fairleads cannot fail. Rollers are also huge compared to hawse. Parts that cannot fail > parts that fail
hang rollers off the front of your rock crawler and it only takes one hit and now you have a roller that doesn’t roll. Rollers also break.
here’s my buddy missing a whole roller, notice the bottom mount is bashed in (not his biggest issue at the time, though)
Fair enough like i said i have been problem free on my older jeeps/ trucks i do like the lower profile of the hawse thats why i went with it for my trailer then i can pull the winch out of the reciever and stash it in the tool box...
so from what i can see from the feedback you all have given, grandpa can replace the heavy steel with synthetic, thanks men
Research what size and length you should get. My 8000lb warn on my Toyota had 90ft of 5/16 steel cable and I bought 100ft of 3/8” synthetic line and I think that was a poor choice.
It fit on the drum but keep in mind I wound it perfectly. Unevenly wound I may have some issues.
YMMV
i.ve got 90" of 7/16 on a 12k winch and figured 100" of 3/8 would do it, at least dealer said that.
12k line for a 12k winch ok or should i get heavier ?
YMMV
As long as you never exceed the rating on the lowest rated piece of equipment, you’ll be fine. I hesitate to tell someone what rating to buy for their application
I would do 85ft of 1/2 personally i can see it on amazon in that flavor i would never downsize going from steel to synthetic
So the 2018 and earlier PW have what is labeled as a “M12000” winch, but people have found that it actually is an M15000 under the skin. 3/8” is sufficient, with a ~17.5k minimum tensile strength. I have 7/16” line which has a 21k MTS, which gives me a bit more breathing room/factor of safety.
I also run a short line, 65ft (~55ft useable), and carry and extension. Short line means i just pay it all out to get the most pulling power (last wrap on the drum), and I don’t have to worry about it stacking up on one side and getting pinched in the cross bars. It’s also easy to turn it into a 2:1 with the short main line and an extension
