When to install the Front grill cover
Rgpracer
2020 6.7........never owned a diesel, here in Wichita it is single digit temps and has been/will be for next few days......when is the front cover needed?
Thanks
Official word has been when the temps are going to stay below freezing. Up where I am, that's about 5 months that the winter cover is on ;)
Some have found the trucks work just fine without it, but it does make a difference -faster warm ups for sure, and likely easier on the engine when first start driving.
B
B
Its needed for the emission systems not for faster warmups thats what the thermostat does... if you dont have proper operating temps 90*C (190*F) then you can cause issues with the dpf and egr that the dealer wont cover under warranty... the grill shutters are not a replacement for the cover like some people think....
Thanks
Anything 32 and under is required i leave the flaps closed unless it is above 32 the owners manual calls for 18 and below requires the flaps closed
I didn't know that; thanks!
B
That’s good to know. I glanced at the grill flaps after seeing it mentioned but thought it was automated. I need to look these things up.
Not the grill shutters behind the grill the flaps are on the grill cover... see the squares on the winter front
Oh. Gotcha. I didn’t get that, not a common option in Az.
I still want to look into the grill shutters and understand what’s happening with them.
That was my question.
My truck is getting a DEF tank and components completely replaced because it all froze. Under warranty. The module went out and they replace the entire unit. I guess it’s an easy switch out!
Should be on a road trip but just got to wait for it to be out of the shop to leave with the family
Def is mostly water with a heater in the tank why would they not just thaw it out lol
I have the grill cover in storage behind the rear seats....It will never see the light of day!
Hopefully...we could end up like Texas I guess? :D
I've been running around between Colorado and back home to Texas over the last week and a half. no cover. truck ran great. lowest temps I saw were -5f.
Spent 10 years in Colorado and never used a grill cover on my trucks. I'm sure it would help warm up a little quicker but it certainly was never an issue not using it.
Is to be used under 32F... However, I will put the cover on when the engine cannot get up to temp. I have seen it get to 190 within 10 mins (when plugged in) even when it -8F. I'm interested to see the affects on trans temp though.
