nshirvanian
Let’s see how it turns out. I read others have installed these wheels and 35/12.50/17 with no level and they fit no rub.
I have a 2500 diesel. Will post photos and feedback shortly.Do you have a regular 2500 or Power Wagon?
I have been running 35s on my 2019 PW since day 1 on stock rims with very little rub and no issues off road.
Looking to move to the AEVs and upgrade to 37s some point soon.
Interested in seeing some pics and your feedback after the install.
Well so far so good. Fits perfect in my opinion. No rubbing at all. Looks factory!Do you have a regular 2500 or Power Wagon?
for the record if you have a device to calibrate your speedo 33.7 will be spot on with the Toyo R/T's.Well so far so good. Fits perfect in my opinion. No rubbing at all. Looks factory!
Thanks man.Looks great. Congrats!
I don’t yet. Do you recommend a tuner?for the record if you have a device to calibrate your speedo 33.7 will be spot on with the Toyo R/T's.
right on! Perfect setup.should be golden.
I use an AEV procal snap and also have lowered my tire pressure threshold. I run 40F and 32RI don’t yet. Do you recommend a tuner?
Thanks. I’ll check it out.I use an AEV procal snap and also have lowered my tire pressure threshold. I run 49F and 46R
+ 1 on AlphaODBGet setup with AlfaOBD and you can do much more than just tire size and TPMS.
Is that the 21 with the new rims?
that is a 21 75th anniversary edition...Is that the 21 with the new rims?
They are 17x8 +43 I believe. I posted it here somewhere else when I went out and looked at it.Those rims look great. Haven't been able to figure out of they have a wider offset. Than the 2019 & 2020s
