Rockcrawlindude
a rock crawlin’ dude
What did you end up setting them to? or just a reference point?
Correct, they now match, as suggested in the Thuren documentation. I'm guessing with tools and a level surface, it could be dialed in a little better, so I'm sure your approach will be even better.Thanks. Makes sense to me. They’re the set to the same now? Mine are the same from the factory so I will adjust them the same.
I believe I read the spec was 220lb ft so you confirmed that for me. I just checked and my 27mm socket is 3/8” drive, I believe it was for a drain plug or something. I just ordered a 27mm 1/2” impact socket based on your findings.
I plan on using a digital magnetic angle finder and zeroing it on the garage floor and then measuring the caster angle on top of the ball joint. Then I will measure again after I install the lift and see how much it changed.
As long as it handles predictably and doesn’t clap out tires then it’s GTG!Correct, they now match, as suggested in the Thuren documentation. I'm guessing with tools and a level surface, it could be dialed in a little better, so I'm sure your approach will be even better.
CorrectThuren says one notch to the rear of the middle for their 2.5” coils.
Mine is one notch forward of middle, so it’s two notches forward from the Thuren 2.5”.
What notch did you settle at? If I followed correctly, you’re two notches back on both sides?
@LateToTheParty is the drag link length adjusted by the nut that is between the tie rod end on the pitman arm and the drag link itself? I see the adjustment clamp there on the drag link and there is a hex nut but it looks like it’s attached to the tie rod end.Happy to report that it was easier than I was making it to be in my head.
27mm socket on the outside
24mm wrench on the inside
Loosened the outside nut, adjusted the bolt with the 24mm welded inside nut, then re-tightened.
Torque wrench broke the bolts free at about 215 ft/lb, so I tightened them up to the same
That is correct.@LateToTheParty is the drag link length adjusted by the nut that is between the tie rod end on the pitman arm and the drag link itself? I see the adjustment clamp there on the drag link and there is a hex nut but it looks like it’s attached to the tie rod end.
Thanks. I assumed that was it. I’m Used to left hand thread TRE on one end and right hand thread TRE on the other end and spin the drag link to adjust like a tie rodThat is correct.
Yeah. I laid under there for a while looking for those jamb nuts that I was used to, before cautiously giving it a go.Thanks. I assumed that was it. I’m Used to left hand thread TRE on one end and right hand thread TRE on the other end and spin the drag link to adjust like a tie rod
