For those that have the air suspension, there is a new “Bed lowering mode” that can be used to drop the rear end by 3 inches. The alternate trailer height drops the rear by 1 - 1.5 inches.
To access the bed lowering mode, you have to go into Apps on your Uconnect screen, scroll over until you find the icon labeled “Bed lowering”. This button is not available anywhere else. You can drag it to your menu bar as I did and replaced my climate button as it’s redundant.
[MOD NOTE: Bed lowering on 3500 trucks only lowers (at most) 1")
Once pressed, the 7” cluster screen will indicate its lowering the bed and drop the bed 3”. It will indicate “bed low”. The bed will raise again until normal height is achieved if the vehicle moves over 25 mph.
This is very handy if your trailer needs a drop greater than the alternate trailer height can allow for your hitch ball to separate from the trailer tongue.
It’s not really documented very well on the inter web nor in the manual clearly stating that the bed lowering button will completely drop the bed beyond the alternate trailer height. Figured it will save someone the research.
Enjoy!
Enjoy!
