Put a topper on my truck...
RANCH Fusion ... I wanted frameless glass on the sides but I did not have the time to order before heading out of town.
I still like the look with it being all black
Bro I absolutely love it. Exactly what I am going to do as well. So nothing else done, just 37’s on +18 offset and some light trimming?
Nothing else had been done. Just trimming of the plastic liner and the pinch weld. Pinch weld is easy to modify with a flap disk. The plastic liner can be easily cut with a razor knife heated with a propane torch. I still have a little bit of rub but I will continue to trim it a little bit at a time so I don't overdo it. I think it might slightly rub on the swaybar but it is not really noticeable. I need to inspect it but I haven't been able to really look at it since last Sunday. I will be going to the Carli swaybar when I lift it in a few months.
That looks great! I like the lines of that topper.
What are you putting on?
I swapped the Westlake for Goodyear Endurance on our 2018 303RLS. Heard all the new Reflections were coming with them now too?
I went with the sailun S637 ST tire.
It was that or the endurance.
The 2021+ are coming with the endurance. If they did I wouldn’t have changed anything. However with the westlake E rated tires and max PSI it hardly covered my GVWR.
With the new sailun tires at 100 PSI I’m about 1200# over my Gvwr in load rating and at 95 psi I’m about 950# over GVWR in load rating.
The endurance is a great tire though I just wanted to load rating personally and a heavier tire.
Once again wish I would have waited to the Megacab.
Good looking rig. I have a GD Momentum.
Thanks.
What momentum for you have? Did your trailer come with the westlake tires? I think they put the G rated ones on the momentum. Those have been good tires overall.
Thanks.
351M
G Rated Westlakes standard.
Damn fine choice. I realized after seeing more pics you probably have a higher GVWR on that model than my little 303RLS. I've got more available capacity in the tires (around 900lb each) than the wheels (around 700lbs each). I'm not a fan of the G rated heavy stiff sidewall tires for lighter rigs as I think they just beat up the suspension. Maybe I'm wrong, but I've seen many post of failed suspension components from using overkill tires.
My mantra is the GY are perfect for ~12K or under, and the Sailuns are great for GVWR over that.
