Its for Plow lighting..... if you don't have foglights you don't have the button you are most likely seeing the cargo light buttonmy 19 6.7L 2500 did not come with fog lights. I was tracing the wire harness because I have the fog light button on the knob. This way I would be able to install after market fog lights. However, I found these wires bundled and taped together under the fuse box. Can anyone help me with this?View attachment 11197View attachment 11198
You’re right!! Thanks I don’t have the button. I guess the best option is to install aux switch for fog lights. If the plow lighting cables are there, is there other side connected to anything? A button or something? I tried to look into a diagram. There are no open aux switches from factory installed.Its for Plow lighting..... if you don't have foglights you don't have the button you are most likely seeing the cargo light button
They are made to connect to a plow relay harness or isolation moduleYou’re right!! Thanks I don’t have the button. I guess the best option is to install aux switch for fog lights. If the plow lighting cables are there, is there other side connected to anything? A button or something? I tried to look into a diagram. There are no open aux switches from factory installed.
Do all the trucks (trims) have these blunt cut "trigger" wires present?They are made to connect to a plow relay harness or isolation module
From my understanding yes i have heard yes and no about the pw thoughDo all the trucks (trims) have these blunt cut "trigger" wires present?
I could not remember i know before 2019 they did not get them..... on a side note any idea what the 7th wire in that bundle is for? There is a solid green (i think green) on my 19 and i can not find anything about it
All 2015-2018 HDs get the wires except for power wagon.I could not remember i know before 2019 they did not get them..... on a side note any idea what the 7th wire in that bundle is for? There is a solid green (i think green) on my 19 and i can not find anything about it
Correction what I said above about that “green” blunt cut wire. It should be green/gray stripe, and it is for a PTO wired remote.I could not remember i know before 2019 they did not get them..... on a side note any idea what the 7th wire in that bundle is for? There is a solid green (i think green) on my 19 and i can not find anything about it
Ah makes senseCorrection what I said above about that “green” blunt cut wire. It should be green/gray stripe, and it is for a PTO wired remote.
If you unclip and lift the fuse box it will be there, mine was at the very bottom of the harness bundlethat's interesting. I don't have that wire bundle on mine.
