I found used seats and a steering wheel out of a 2020 BigHorn and installed them. I am still needing the clock spring for the steering wheel and the center stack with the Heated Steering wheel and seats buttons. While I was installing the seats I noticed that my plugs under the seat are pre-wired and I have what looks to be all the wiring needed to make this work on my 2019 tradesman. I did not need to add any additional wiring to make the power adjustments on the seat work.
One further observation is when the truck is started and the outside temp is at or below 40 degrees the driver seat is heating up as you would expect when it is cold out which is also leading me to believe all the wiring is already in place. I ordered an unlock cable so I can change the AlfaOBD settings in the BCM for the heated seats and wheel but I have no idea what settings need to be changed to get the "controls" app on my 8.4 uconnect radio. If anyone knows and can share it would be much appreciated.
Once I get the clock spring and center stack I will keep you all updated on the progress.
