Wiring Diagrams?
mikenacarato
TN
Does anyone have access to wiring diagrams? I am looking for the following under the dash to wire my emergency lighting controller to
the fancy led drl lights in the brightest mode for each headlight
each brake light
the horn ring
TIA
Did you ever get any help on this wiring diagram? I'm looking for the horn wire under the dash as well.
Sent from my ASUS_Z01QD using Tapatalk
Do you have the vscim module? If so you can set up wags for front and rear through there it just requires grounding the wires from the vscim harness with a switch
I ended up just getting a feniex wig wag module and tapping into the headlight circuits. Seems to work perfectly so far
For a few bucks you can access and download whatever you need as your heart desires
