BamaStar
You have a sunroof or is it your 3rd brake light?Honestly, I wish I only had this issue. Getting water in the hood isn't nearly as bad as getting water in the cab![]()
Have you done the Home Depot weather seal fix yet? I had to do that one on my 1500.I assume the brake light. No sunroof. On my previous RAM 2500, I had both rear window (non-slider OEM) and brake light leaking.
Well... normally dealers will work to fix water in the cab... but not on the hood one.Honestly, I wish I only had this issue. Getting water in the hood isn't nearly as bad as getting water in the cab![]()
Just curious where are you located, and what dealer did you use?Thanks for this info. My hood was filling and I took my truck into the dealer yesterday. They are covering it under warranty and replacing the badges. This site is a great source of information. You guys rock.
This. I had a ford driver door full of water a few years back. Drain was clogged.Have you looked for drain holes elsewhere and if they are clogged?
Annapolis, MD. Bayside Ram of AnnapolisJust curious where are you located, and what dealer did you use?
Me too, 2009 F150. It was nasty in there.This. I had a ford driver door full of water a few years back. Drain was clogged.
Was a ‘10 here. Same body styleMe too, 2009 F150. It was nasty in there.
I took my 2019 ram 2500 hd to a dealer in Gloucester Va. They told me they never heard of the issue and the water will not damage the hood. I asked if I could drill a hole in the lover part of the hood to assist in drainage and was told it would void the warranty... I am at a loss because I am sure damage will occur over the years.....So I took my truck(2019 RAM 3500) in for the step recall and a couple other items. One of them was that every time it rains or I give my truck a bath, the hood fills up with water and drains when I open it. The dealer has told me it is ok as the hood has drains. I am thinking it's like saying that my shop roof can leak as long as I have a floor drain. Thoughts?
So, the aluminum hood won't rust, but it will corrode. Chrysler had no problem covering mine under warranty.I took my 2019 ram 2500 hd to a dealer in Gloucester Va. They told me they never heard of the issue and the water will not damage the hood. I asked if I could drill a hole in the lover part of the hood to assist in drainage and was told it would void the warranty... I am at a loss because I am sure damage will occur over the years.....
Unfortunately, lots of people do not know this.So, the aluminum hood won't rust, but it will corrode. Chrysler had no problem covering mine under warranty.
Yah I got the same dumb ass answer! There should be a recall on this!So I took my truck(2019 RAM 3500) in for the step recall and a couple other items. One of them was that every time it rains or I give my truck a bath, the hood fills up with water and drains when I open it. The dealer has told me it is ok as the hood has drains. I am thinking it's like saying that my shop roof can leak as long as I have a floor drain. Thoughts?
Yea, I swapped mine for black. The foam is just enough to keep it from rattling. No way it seals out the rain or car washIf you're wanting to know what it looks like behind the badge, this video is queued up at the badge removal. Seems like they should all leak.
Of course they didDealer told me it was supposed to fill with water
If he was really enterprising he would have offered to winterize it. RV and boat antifreeze will work, but I prefer blinker fluid for peace of mind.Dealer told me it was supposed to fill with water
