Here is a pic I stole from another forum. It looks like the gap is normal. LOoking back at the parts diagram I posted in an earlier post, there's only one lower trim piece.I installed it.
Part no. 6YK08TX7AA (black with bighorn on it)
My tradesman has a black dashboard and this matches perfect. Only 1 issue the bezel underneath is smaller on tradesman than bighorn so I have a gap. I'm searching for that part number now.
First remove the radio there are 2) t20 torch on top under the rubber mat than it pulls out from the clips. Watch a video on that to see how hard you gotta pull- Its in there.
Next remove the bezel ( long trim piece above lower glove box and below cubby. It's held in with clips. Cargill because one clip by the radio trim is backwards. Go easy and watch inside as you go. ( I didn't and that clip shot into the dash idk where)
See the one tab missing his clip. That's the one that's backwards. Just want you to watch that guy. if you go to yank the whole thing off that whole tab might break.
Next remove glovebox.
Under the glovebox is a fabric cover with 3 plastic push pins. Remove those pins ( buy some btw). View attachment 9485
Under the cover you will see 2) screw with 7mm heads. Remove those.View attachment 9486
Go to the top where you just removed bezel there are 6 screws staggered and 2 other on the left by radio area. Remove all 8.View attachment 9487
Now is when you can remove glove box. With the two lower screws removed it is only held in with clips pry it looks with a plastic tool or give a tug.
With the glove box removed look up under the dash there are 2 screws holding in the cubby. Gonna need a 12" extension to reach up in there.View attachment 9488
Once screws are removed the cubby is ready to be removed. It doesn't have clips.
Install the upper glove box. The black tabs on it's backside sit below the tabs that held the two screws.View attachment 9489
This is the tab. Notice my cubby tab is attached and. There is no cubby. So that how I found those.
When you go to put the screws back in slide a piece of paper in the socket so the screw doesn't fall out of the socket.View attachment 9490
Once those are back in it's time to put it all back together.
Took me about 45 minutes to figure it out and install it. Not a bad job at all.
I will update the trim bezel part no when I confirm it's correct.View attachment 9499View attachment 9501View attachment 9500
Do the one that goes in higher trim trucks seem to be any different like as in the placement pf where it attaches or different tabsI have been a big proponent of putting in a upper glove box since I got my '19 Tradesman. I have never attempted to modify my truck because I have a long history of modifying things by breaking them!
so, I figured that I should just wait for someone with the knack to do the mod and show us how. Thankfully the "ass kicker" stepped up and did it. The gap under the upper glove box door seemed excessive.
I went to my dealer today and looked up the part numbers for the " black lower trim" using the vin number of both of my trucks other one being a Big Horn. They have different part numbers for the lower trim.
For the Tradesman- 6YK20TX7AA
For the BighHorn - 6YK21TX7AA Mopar list- $58.20
That may explain the poor fitment with the Tradesman lower trim.
That I don't know. Jackmup did the install and I am sure he will come up with the correct trim piece. Since there are different part #s for the same color trim I would assume that the lower trim for the BigHorn will take up the space under the upper glovebox door.Do the one that goes in higher trim trucks seem to be any different like as in the placement pf where it attaches or different tabs
Great photo thanks. The gap I have is larger than that about 1/4" I ordered the bezel below it. I think it's right I hope. We'll see. I need to actually hook up with the parts guy at the dealer. It's not very expensive though and it finishes the dash off nicely.Here is a pic I stole from another forum. It looks like the gap is normal. LOoking back at the parts diagram I posted in an earlier post, there's only one lower trim piece.
Maybe someone else can chime in to confirm.
I ordered it. Starting to realize that the "TX" means black.I have been a big proponent of putting in an upper glove box since I got my '19 Tradesman. I have never attempted to modify my truck because I have a long history of modifying things by breaking them!
Nice job!Oh one other thing. The cubby has small tabs about 1/16 along the top that book under the the dash. Just so you are aware. A small pry it push if they hang up.View attachment 9502
Nope. It would be nice if they offered a plain door or one with RAM on it instead of the trim level.Can I order the glove box without BigHorn emblem?
I was just thinking if I add anymore crap to this truck I should have got the laramie.Nope. It would be nice if they offered a plain door or one with RAM on it instead of the trim level.
It's funny you say that because I was thinking that I can't get too carried away making alterations because not matter what I do or how much I spend in the end it will still be a Tradesman.I was just thinking if I add anymore crap to this truck I should have got the laramie.
It will cost you more to buy laramie then add the stuff. If you purchase Laramie you are forced to buy some options that you don't needI was just thinking if I add anymore crap to this truck I should have got the laramie.
How long have you had it?View attachment 10543i think it's too late for me I need to seek help, I should have bought a laramie but the price tag scared me.
Would be funnier if it was a strap on that said bighornanyone know if that bighorn logo is a stick on? i'd be tempted to do this one, with no gap and no ridiculous bighorn logo.
