jarrington
It's becoming really obvious that the Firestones aren't going to work for me - I live at about 9000 ft in the CO mountains with about 2 miles of dirt road between the highway and my place. It's basically snow / slush / ice / slop for at least half the year. Heck, even getting out of my driveway is an adventure with the POS Transforces. My old Suburban is on worn Goodyear Wrangler Adventures and they feel like studded snows compared to the Firestones.
I'm hauling a slide-in truck camper and will be right around the GVWR most of the time, so if I'm splurging on new rubber I figured I'd also go with a bigger tire to bump up the tire load rating to give myself some breathing room on tire capacity. As I understand the stock wheels are only rated at 3500 lbs, actually a bit below the tire rating, so they would need an upgrade as well.
Current thinking is Michelin Defender LTX M/S 295/70/R18 with Icon Rebound HD (4000 lb load rating) in 18x9 with a +12 offset. I'm not lifting or installing fender flares, will I have any issues rubbing the fender liners / etc with this setup? The Method NV 305 HD is the only other wheel option I could find with a heavier load rating than stock (4500 lbs!!!) but they're quite a bit more expensive than the Icons. They have a 18x9 with an 18 offset, so it'll stick out a little less than with the Icons.
Anybody with a similar setup?
Also, I've heard the Michelins are fantastic tires and decent in the snow even without the 3 peak rating. My second option would be Goodyear Duratracs but those are a lot more than the Michelins and this rig will stay on-road close to 100% of the time so don't really want or need the more aggressive on/off road tread of the Goodyears.
Thoughts?
Thoughts?
