2020..halogen lights..i kinda think they suck
FWIW, I replaced the low beams and high beams w/LED's in my 2020 Tradesman and have no issues with oncoming glare for the lows. They have a very defined horizontal cut-off line, and much improved light over the OEM halogen bulbs.
GTR LED low beams
I also used the same brand for the highs and they really throw some light...
Do they flicker at all? I read that just putting led bulbs on rams cause them to flicker...
Mine don't flicker. The GTR's that I purchased come with a PWM module that you install with the bulbs to prevent that. It is also compatible with RAM's canbus system, so it doesn't make the truck's computer sense any problems.
have a link to your setup?
so I put in the phillips extreme bulbs in the low beam and for 15 mins work and 30$ theyre awesome..waaaaaaaaaaaaaaaay better than stock..no bs with the computer...just stick em in and nice white light about 50% better id guess....well worth it..simple easy upgrade....should've took some pics but I didn't since I didn't think it would make that big a diff....did tho
I run Hikari led bulbs low beam only, 6000 lumin with the anti flicker module.
These tuck nice into the headlight housing with rubber boot seal .
Very nice and clear great light doesn't blind drivers..
I also have Luyed Led cargo lights, and reverse lights..very bright and can bus compliant, do your research or you may get and error on a bulb out..I researched allot on YouTube first..
yea..sorry but I hate led..theyre just bright as crap..not good lighting in my exp......i have an led light bar and ive looked at yellow led fogs but I still like real light better
