Jimmy I had mine programmed and locksmith in West Allis, WI. Whitlow's. Took them very little time and they had the wiTech.Currently, the only tool that can program a 2019+ fob is the dealer wiTECH. Locksmiths don’t even have equipment yet that can do it.
You not the only one https://hdrams.com/forum/index.php?threads/truck-wont-unlock-after-remote-start.2818/ I have mine installed by the dealer and it does the same thing. Can you check one thing for me. Get in the car (with engine off) start it with the start button (not the fob) and try to lock the doors with the button on the door. Are you able to do it? Also if the remote wasn't installed by them at the factory RAM won't help you. They don't care.When I start my 2500 RAM 2020 LoneStar Silver Edition the FOB won't unlock the doors? The issue only arises after a remote start, I can unlock the doors with FOB when truck is not remote started. Any thoughts or similar problems? This is a factory remote start, not after market.
mine works doing that ie starting using push button and then locking or unlocking from door button. It will not however lock or unlock using the remote when starting with the push button. Also if inside and starting with remote and then using the door unlock buttons you will set off the horn honking alarm.You not the only one https://hdrams.com/forum/index.php?threads/truck-wont-unlock-after-remote-start.2818/ I have mine installed by the dealer and it does the same thing. Can you check one thing for me. Get in the car (with engine off) start it with the start button (not the fob) and try to lock the doors with the button on the door. Are you able to do it? Also if the remote wasn't installed by them at the factory RAM won't help you. They don't care.
My won't unlock the door after remote started and I'm not able to lock the doors from inside with the button on the door while engine is runningmine works doing that ie starting using push button and then locking or unlocking from door bottom. It will not however lock or unlock using the remote when starting with the push button. Also if inside and starting with remote and then using the door unlock buttons you will set off the horn honking alarm.
Do you have the tailgate release button on your fob? Does that button work while in the truck when the other fob buttons don't work? Interesting ro know if it's all buttons or just the lock/unlock. That may help diagnose further.My won't unlock the door after remote started and I'm not able to lock the doors from inside with the button on the door while engine is running
I know when I tried to unlock the truck after remote started and it didn't , I assumed the same thing and thought maybe FOB is bad. So I tried other buttons and they didn't work either. Gate release , remote start off. It like the hub wasn't picking the signal from my fobDo you have the tailgate release button on your fob? Does that button work while in the truck when the other fob buttons don't work? Interesting ro know if it's all buttons or just the lock/unlock. That may help diagnose further.
I did not check but I doubt it would as a safety feature, probably don't want your tail gate popping open if you accidently hit the button going down the road. I will check later but can not right now.Do you have the tailgate release button on your fob? Does that button work while in the truck when the other fob buttons don't work? Interesting ro know if it's all buttons or just the lock/unlock. That may help diagnose further.
will your key open the door in this situation?I'm disappointed with ram customer service. They told me mopar is aftermarket and I'm on my own now. This is so embarrassing standing next to my $40 grand brand new truck on the parking lot and trying to unlock it. While all the employees keep asking you "is everything all right?"![]()
If you mean the emergency key then yes. With FOB I have to stand there and keep pressing it till it unlocks.will your key open the door in this situation?
