I agree that "reports" can be way off. Part of it is making sure the tank is topped off the same each time, and I'm not sure that a single tank fill-up will be consistent enough.
For example, there was an interesting article on TFL trucks comparing the new Jeep Gladiator diesel to the new F150 hybrid. They did their 66 mile loop, and each truck went one round empty, then filled up and went one more round towing the same trailer, then filled up again. I like the methodology; same day, same loop, driven side by side at the same speed, etc. Several of the fill-ups were close to what the EVIC said, and what might be expected. The last fillup of the F150 driving empty, the EVIC showed about 23mpg. But when the hose clicked off, and they calculated the mpg it was over 29mpg! First thing I thought of is there is no way on a 66 mile loop and putting in 2-3 gallons total, that you could count on the fuel pump clicking off at precisely the same level of fill each time. But, their whole fuel mileage analysis depended entirely on when the pump clicked off.
If TFL doesn't get it right, how many others also don't get it right? And, not saying they are being disingenuous, just that the methods are suspect if calculated on a single fillup, especially a partial one, based on when the pump clicks off.
Now, if someone reported their mileage over several fill-ups on a 1000 mile trip or so, that report would be inherently much more accurate.
I kept a pretty good log on my old truck on Gasbuddy, and will do so on my new truck also. But, I'm working from home now, so have put only a couple hundred kms on the new truck in 2 weeks. Will take awhile to figure out anything at this rate ;-)
B
Thanks for the input. Not sure if I want to jump in just yet. My 1500 hemi sucks on mileage with 35’s and 3” lift. Plus we pull at travel trailer. That’s why I’m looking.
Well, if you add in the 35's and the 3" lift, your economy has already gone down in addition to the hemi. OTOH any trailer you can safely pull with the 1500 gasser would hardly register when pulling with the 6.7. If you would plan to lift a diesel HD and add bigger tires, then your numbers won't match what you're seeing here either. They will suffer. And again, it will help if you mention what kind of trailer, and what kind of terrain. The 6.7 factually, with a larger and heavier load, literally got twice the mileage for me on the exact same route, at higher speeds, than did the 2500 6.4 Hemi as an example. I'm not exaggerating. It was almost twice the fuel consumption with the 2500 6.4 Hemi. BTW, I mean that by measured gallons, not what the truck electronics said. But the needle on full, and then the number of gallons to replace to get it back to full.
What were the loads and route types in your example?
I'll even provide the general starting point, destination and return. Starting was in the vicinity of zip code 15330. Destination was zip code 16239. If you use mapquest you'll be able to see the likely routes and get a better view of the terrain. Using Interstate 79 and Interstate 80 for quite a bit of the drive, but certainly not flat at all. The 2500 6.4 was a 2018 so it had the 6spd auto. Both were crew cab, 2500 short bed. The 6.7 was pulling a gooseneck 3 horse slant trailer with small living quarters, full gear, etc, and two horses. The 6.4 was pulling a smaller bumper pull V-nosed trailer with almost no gear, but the same two horses. I would estimate the gross trailer and equipment weight for the 6.7 combination to be around 10000lbs. I would estimate the gross trailer and equipment weight for the 6.4 combination to be around 6000lbs. Both rigs drove the EXACT same route within a week of each other. Weather was essentially about the same -ambient temps, no rain, etc. Even same time of day. The 6.7 rig (gooseneck) is much taller, and completely square front. The 6.4 rig is V-nosed. With the gasser, I was not able to maintain the same speeds whatsoever. I could not maintain 65mph across the Interstate 80 portion, or most of the Interstate 79 portion. The 6.7 had zero problem whatsoever.
I'll also mention that I also pulled the same exact route and loads as I did with the 6.7 with my '04 5.9 NV5600 truck. I got about 4 mpg less than with the 6.7, which I attribute to the 4.10 rear end making me run at higher RPMs. This however was not within just days - it was probably within a couple weeks, but similar outside conditions.
Thanks for the info. I wish I could see that much difference with what has been a similar combo of vehicles.
From new, 2016 Ram Power Wagon w/ CCSB 6.4, 6sp, stock 4.10s and 37" tires. Then re-geared to 5.13 a few years later. Then replaced with 2019 2500 CCSB 6.7 SO this April.
I've seen 10-15 difference in mpgs whether highway, towing the buggy hauler or a limited run with the 22' camper that's been sold due to limited use. And I've put a jug of DEF in less than 1000 miles per. Now a little over 9k on the odometer.
It downshifts less and is quieter, but I regret and miss the old truck.
I guess I don't understand. If you're getting 10-15 more mpg, it's quieter, shifts less (and would obviously have more pulling power even without the 5.13 rear end) even with a jug of DEF at 1000 miles, why in the world would you miss the old truck? I absolutely prefer driving the 6.7 (or frankly the 5.9) in every respect (except for shifting the '04 NV5600 in traffic). There was nothing whatsoever about the 6.4 that I liked better than the 6.7 except for the lower purchase price.
Crap, I forgot a word/symbol in there. 10-15% more mpgs (so 1-2 mpg).
Basically I am not getting the benefit out of this diesel that was hoped for, and I thought I was realistic with my hopes going from a built PW to a stockish Diesel. Plus my first experiences with DEF haven't be pleasant.
That DEF use is about what I am seeing. 400 MPG at best.Gotcha - I understand. To be honest, I truly think it is highly dependent on a lot of factors. The HO is going to eat more fuel - that's just normal. Meaning compared to the SO.
My '04 broke down so I had to borrow the '18 6.4. We decided it was time to buy a new truck during that haul, and frankly I was using it as a "test drive" to see if I could save money and buy a 6.4 rather than paying the extra for the Cummins. I knew VERY quickly that I wouldn't be happy at all. But even then, I was terribly surprised when I was forced to fill an empty tank before I even got to the destination in the 6.4 - and then again on the return trip. Same size fuel tanks and the 5.9 and the 6.7 not only "could" but quite literally "did" haul heavier, faster, and did the compete trip with half the fuel. I was amazed. And bought another Cummins.
I am also not happy with the DEF consumption and am looking into it. With only 1700 or so miles on the truck so far, I'm hoping it's going to taper off. If not, I'll be talking to the dealer and FCA pretty soon. I'm averaging 350 mpg of DEF.
