kobra
In Canada we won't get the Toyo AT3s until next year. It looks like I can get the Falken Wildpeaks in LT295/70R18 but they are in short supply so I will know for sure soon.
As to the reviews, it seems they are both well reviewed for the things important to me. If I had to summarize, I think the Toyo's seem to rate a bit better on dry handling with the Falkens a bit quieter. Both seem to rate high on wet and snow, with good wear. It's hard to find a bad review on either though.
I can't really find much info on how much of a hit I might expect for fuel economy. If anyone has some ideas there, I'd be interested.
As to the size? I like the idea and the looks of a much bigger tire, but with a priority to tow a 17k 5th wheel for about 30% of my miles, I think staying reasonably close to OEM will be better. The 295/70R18 is about 3% taller and 2% wider, so very close to the OEM Transforce.
Also, I like that the above size gives a load rating of 129, so I should be able to run everything about 10lbs less air and keep similar load carrying. Less air, and about 20% more sidewall with 18" instead of the 20" OEM rims on the Limited, should give me a bit of a softer ride.
I'm going to pair them with Method 305 NV HDs in matte black. That gives me a 4500lb rating in an off road "bead lock style" rim. I don't see many other rims of that style that are rated that heavy.
Even so, will take a few weeks to get everything, so I will post pictures when I can.
Thanks for all the help, guys, really appreciated!
B
B
