mikenacarato
Hello folks. First post.
I've owned my pw for about 7 months now...
One month after getting it off the lot:
Welcome and nice truck! Saw the Rutherford tag, I work in La Vergne!
Thanks! I tend to wave at other PW owners, but there aren't many around here!!!Welcome and nice truck! Saw the Rutherford tag, I work in La Vergne!
Any pics of that rhino rack?Hello folks. First post.
Added a few things to it since then:
(Yes, there is another RAM in the driveway)
Did you do anything to recalibrate your speedometer, or are you just accepting it being slightly off?
As far as I know there isn't a programmer yet, so just dealing with it at the moment. GPS shows me how fast i'm goingDid you do anything to recalibrate your speedometer, or are you just accepting it being slightly off?
Sent from my Pixel 2 XL using Tapatalk
AlfaOBD (+ an OBDII bluetooth dongle and bypass cable) as well as the AEV ProCal both work to update tire size and correct the speedo.As far as I know there isn't a programmer yet, so just dealing with it at the moment. GPS shows me how fast i'm going![]()
huh I actually have an AEV ProCal from my last truck. I heard it wouldn't work due to the added security module they put in for the 2019+ ones. Maybe I'll give it a go.AlfaOBD (+ an OBDII bluetooth dongle and bypass cable) as well as the AEV ProCal both work to update tire size and correct the speedo.
It needs to be the version specific for 2019+, which includes the bypass cable.huh I actually have an AEV ProCal from my last truck. I heard it wouldn't work due to the added security module they put in for the 2019+ ones. Maybe I'll give it a go.
www.aev-conversions.com
Awesome thanks! I hadn't seen that yet!It needs to be the version specific for 2019+, which includes the bypass cable.
AEV ProCal SNAP for 2019-2024 Ram HD
Take control of your 2019+ HD Ram 2500/3500/4500/5500 with the AEV ProCal SNAP module. This module customizes vehicles and optimizes fuel efficiency.www.aev-conversions.com
Awesome in the green!
I have a 2020 power wagon and I have a Procal Snap and it works great. My buddy has also has a 2020 PW and is also using the Procal snap with no issues. I have my speedometer calibrated and also lowered my psi threshold to 45psi front and rear. I actually live really close to AEV r&d and the inventor of the procal (brother of the owner) had me bring my truck by so he could see why some people were having trouble with it on new PWs. Mine did not have an issue but he was able to figure out what the problem was and I think you will see them for sale shortly. My buddy had no issues with his either. It is easy to run the bypass security harness just a plug and play. sounds like the issue is the sequence to program uses the brake pedal and the cruise control functions and apparently the brake return delay is different on some vehicles which is what was causing the issues which apparently is an easy fix.
Ahh ok well I just ordered one from another site so hopefully I am in the no problem category!I have a 2020 power wagon and I have a Procal Snap and it works great. My buddy has also has a 2020 PW and is also using the Procal snap with no issues. I have my speedometer calibrated and also lowered my psi threshold to 45psi front and rear. I actually live really close to AEV r&d and the inventor of the procal (brother of the owner) had me bring my truck by so he could see why some people were having trouble with it on new PWs. Mine did not have an issue but he was able to figure out what the problem was and I think you will see them for sale shortly. My buddy had no issues with his either. It is easy to run the bypass security harness just a plug and play. sounds like the issue is the sequence to program uses the brake pedal and the cruise control functions and apparently the brake return delay is different on some vehicles which is what was causing the issues which apparently is an easy fix.
I would talk to AEV first as some have had issues that required a tow to the dealer to get sorted and now that there is the warning they probably won't pay for the repair or tow. You can down load the instructions from AEV's site. They mention only one green star connector and in fact there is two green star connectors on 2020's and it needs to be plugged into the one closes to you which is also a little wider. My buddy first plugged into the one closer to the fire wall as the instructions say it does not matter which slot. He came over and looked at mine and plugged into the same slot and all worked fine. He did have his check engine light on for an hour or so but it went out and never came back. I found AEV very helpful so I would call them first and see what they say. Also on the instructions there is a tech number to call and I would call them before trying to program with it.Ahh ok well I just ordered one from another site so hopefully I am in the no problem category!
Agree, That is nice!!Awesome in the green!
OA
