AirbornePSG
I have a 2021 Limited on order and want to put a cap on the back. Where is the digital rearview mirror camera located? Will the truck cap block it or is it located on the tailgate?
Tailgate at the handle
It’s in the CHMSL, so the cap will block it.I have a 2021 Limited on order and want to put a cap on the back. Where is the digital rearview mirror camera located? Will the truck cap block it or is it located on the tailgate?
The fact that that is where it is on the 1500, and it is the same system on the HDs. I see nothing in the pic on ramtrucks website that would make it look like it is mounted on the tailgate. Keep in mind, the camera is facing straight back, as opposed to downward like the cargo camera, so it mimics you looking straight out the rear window.Do you have a source for this? I ask because the picture on the Trucks website shows a view that would lead one to believe its mounted on the tailgate.
The fact that that is where it is on the 1500, and it is the same system on the HDs. I see nothing in the pic on ramtrucks website that would make it look like it is mounted on the tailgate. Keep in mind, the camera is facing straight back, as opposed to downward like the cargo camera, so it mimics you looking straight out the rear window.![]()
I’m in for any info on how to pull off this mod.Thankyou I appreciate it. This is a bummer, wonder if there will be a mod to move the camera to the back of the caps.
There isn't a mod to move the cargo camera and it's been around longer so... I'm guessing 'no'.Any find a Mod to move the Digital Rearview camera to the back of a camper shell?
Seems like it would be a matter of connecting in a run of appropriate cable to run to the back of the shell. Problems may be: What cabling and what connectors to use? Also how to get the cable out of the headliner behind the CHMSL without water leaking in. I would be very hesitant to try this as there are already issues for some with water leaking in that area and a mod like this may just make it worse.Any find a Mod to move the Digital Rearview camera to the back of a camper shell?
This is the camera for the digital rear view mirror- 68448640AAAny find a Mod to move the Digital Rearview camera to the back of a camper shell?
This is the male to female I think.Since you need more than the 20’ length available, you would finish off with a length that is male to female.
No issue at all. In fact, the 2022s with have an upgraded digital rear view mirror that accepts two inputs, one for the CHMSL like this year, and one for a trailer for tow mode. It will have the same RG174 coax run from the mirror to the bumper (~35’), and will include 52’ of cable for the trailer.This is the male to female I think.
I wonder how long you can make the cable run and have it still work? I am not sure I really need the camera when not towing, but it would be cool to run a length from the travel trailer tongue to the rear of the TT and a camera. Then plug it in to the run from the mirror to the rear of the truck. Then the mirror would show what was behind the TT when towing. But the cable run would be at least 50' so maybe that would be an issue?
Thanks. I did change out the OEM CHMSL today to a much thinner stop light only so the shell will fit fine without having to move it back 3/4" like the installer said they could do. Reconnected the cameras and stuffed the wires back into the headliner. All is fine with no leaks but of course the digital mirror and cargo bed cameras just show black now. I may eventually try to extend them to the rear using your tips but for now will leave as is. One issue I have not thought enough about to solve, if there even is a solution, is this: How to get the wires and camera connections out of the headliner space in a clean way that does not allow water to enter? May not be possible.No issue at all. In fact, the 2022s with have an upgraded digital rear view mirror that accepts two inputs, one for the CHMSL like this year, and one for a trailer for tow mode. It will have the same RG174 coax run from the mirror to the bumper (~35’), and will include 52’ of cable for the trailer.
