TDRamOH
I was playing around with AlphaOBD yesterday to set some other settings on the BCM. I think where I may have gone wrong was setting too many at once as well as nott waiting the five minutes or so to let things soak. My radio is now exhibiting odd behavior and I can't get it restored. I even backed out the BCM settings I had made and reset the radio settings to default through the radio menu and it is still messed up. The BCM settings I set were:
- Tire Fill Alert
- Selectable Tire Fill Alert
- Vehicle Theft Alarm (two settings for this)
The radio now has these (at least) issues:
- Does not recognize the USB port/drive (message: USB Port Not Working). The USB ports still power my phone, and my phone still asks to Allow data transfer when I plug it in, so the ports are active.
- Tuning is odd. For AM when you turn the knob it skips ahead 9 instead of 10.
- For Sirius many of the channels are gone when you click ALL. And you cannot direct tune to a channel - you hit the numbers but they don't register
- For Direct Tune for AM and FM several of the numbers on the keypad are grayed out.
- Any tuning presets are gone.
Another odd thing - I did actually have the Tire Fill Alert set, then for some odd reason kept playing around with it. After setting it again I did see it in the Settings menu, but it was spelled Tyre Fill Alert. Then, after another round of playing with it I had the setting set but it wasn't in the menu. That may have been the point at which the radio was already out to lunch. Yes, I tinkered a little too much, I think.
So, basically, what did I screw up and how do I fix it? I couldn't find the procedure to reboot the Uconnect 3 system, but I did read about pulling the fuse to remove power for a reset. Any ideas will be appreciated Thanks!
- Tire Fill Alert
