What would they void your warranty for?
Unless you brick your BCM and admit to doing so...
Definitely not true. At least not for owners in the US. The Magnussen-Moss act requires that any warranty claim (including voiding of a warranty) can only be done if they can prove that a change that you made (or negligence on your part) caused the failure, and then the warranty can only be voided on the affected parts.Warranty voider if you let your dealer find out![]()
Can anything be done with the reverse lights in the mirror so they just come on automatically when in reverse instead of having to use the bed light switch?
They help you see a trailer when backing up so they are a form of reverse light yes? People....They aren't reverse lights...
If your fog lights are blinding people they’re aimed way too high.Does anyone know how to disable the fog light activation when turning, or with the blinker activated? I installed the Baja Designs amber fogs, and with the fogs off, they are activated when turning or sitting still with the blinker on. Found myself blinding people, and am REALLY curious to see if this can be fixed before hunting next weekend.
The only settings in the BCM I see related to this feature is:Does anyone know how to disable the fog light activation when turning, or with the blinker activated? I installed the Baja Designs amber fogs, and with the fogs off, they are activated when turning or sitting still with the blinker on. Found myself blinding people, and am REALLY curious to see if this can be fixed before hunting next weekend.
[mention]Gondul [/mention] they don’t blink, they turn on until you return the wheel to center. I assume that it is to help show you where the curbs are. I’ve tried everything in the Uconnect, and the closest is “steering directed lights” but that only controls the headlight direction, not the fogs.
I believe you set the pressure alert when you enable it in the radio... Pretty sure I set mine to 80 when I did it.Anyone know if the selectable tire fill alert parameters can be fiddled with? Seems odd that as high as the back tires can be set is 65 PSI. Would like the max to be 80 PSI for heavy loads.
My rears max out at 65 on the radio.I believe you set the pressure alert when you enable it in the radio... Pretty sure I set mine to 80 when I did it.
IOW, no need for AlfaOBD to do that.
