Rogue 2500
[MOD: All offers to buy/sell/trade need to be made/linked to a proper post in the buy/sell/trade forum and ADHERE TO THE FORUM RULES including no buying/selling/trading outside that forum.]
[Failure to do so after one polite warning may result in the posts being deleted. Repeat offenses ignoring the rules may come with a warning and/or ban.]
[Apologies to OP and everyone else reading the thread but it was necessary. If you see a post not adhering to site rules, please help and report it.]
Hi All,
I am going to try and document the process to swap from a jump seat to a console. I have a 2020 Ram 2500 Hemi 4x4 CCSB. If you have other than this, your mileage may vary.
I found another member on this site who wanted to trade and we both had the Laramie trim level. I recommend that you try to do this locally if you can, but it can be done over a distance. The shipping is on the spendy side. It worked out for us doing this halfway across the country.I did my part first by sending the jump seat and parts out first.
Jump seat removal:
Remove jump seat front tray mat to uncover 2 screws.
Take out the 2 screws.
Remove front tray.
Tray before removal:
After tray removal:
Unbolt driver seat
Remove front and rear driver side jump seat bracket bolt. One bolt is visible in the picture above. The rear bolt is under the jump seat accessible when the driver seat is removed or slid forward.
Unbolt female seat belt strap/connector. You will need a torx driver. The female seat belt is bolted to the driver side seat rail bracket.
Unclip wiring harness under driver seat.
1 gray USB
1 Black power port.
Remove harness from under driver seat rail.
(note: I left this wiring harness attached to the jump seat. because I was not sure what was needed to mount the jump seat into the other truck.) There is a USB port inside the top storage bin in the jump seat. It could not be removed without damaging the jump seat so the other member cut the wire. Then sent this wiring harness back. I was the only way we saw to make this happen.
Unbolt passenger seat.
Remove 4 nuts from the passenger side brackets (front and rear) to the passenger seat rails.
Not my picture, I did not take a picture at this point, this shows the passenger side brackets:
Brackets have 4 bolts to the passenger seat rail:
Remove heating/cooling duct extension. May require cutting carpet or carpet removal. This might be done with out cutting the carpet, but that is up to you try.
This is what it will look like after the jump seat remove. (yes, I cut the carpet, because I will not be swapping back.)
Hi All,
Jump seat removal:
Remove front tray.
After tray removal:
Unbolt driver seat
1 gray USB
1 Black power port.
