2019 Big Horn 2500 LED fog light install-Need Help
Use the AlfaOBD Known Working Settings Google Drive folder others have setup. It’s just a couple settings depending on what config you want.
Another question came to my mind. How are the C1 and C4 connectors laid out? Will I be reading the pin locations when looking at the connector from the upper left as C1:1 or is pin 1 on the lower row? Same as C4:13 is this pin location on the top row or lower row?
Thank you ALL!
Thank you ALL!
I remember seeing the link for the connectors, but wasn't positive if that was the connector to use to plug the wire into the BCM or into the LED light itself. Thanks for telling me this information above. Helps me out a lot. C1:1 is the left and C4:13 is the right then? I was surprised we would have to run wiring all the way back into the cab like this. I really thought the wiring would be wired "in" at the factory. Makes it hard. With your method I can use the original factory light switch correct? I mean the one I purchased that has the bed and fog light function in the center.
Do you know how many connectors come in a single purchase? I see it says 1 is .81 cents, but is that for one, or a package. Sort of hard to really tell for sure on their website.
Those connectors are 0.81 cents a piece. I bought 10 of them even though I only need a couple for this project.
