Maybe just a dummy 7 pin plug you can stick in to make it think a trailer is hooked upSince the trailer brake is applied regardless of trailer connection I wonder if you even need the trailer for the test.
Thanks for the info. And the sig line doesn't show on the phone.
It looks like the trailer brake is applied with no trailer when you press the brake pedal, but not when you have the exhaust brake engaged. So to answer my own question, you do need the trailer connection (or at least without a trailer there's no in-cab evidence of trailer braking when exhaust brake applies).Since the trailer brake is applied regardless of trailer connection I wonder if you even need the trailer for the test.
I did the same test today on my 130 mile round trip to Vegas while doing a 35% dpf burn off running 103mph on hwy 106. It made absolutely no difference if cruise or acc or tow haul where on or off. Whenever I put my foot on the brake pedal the trailer brake %% gauge would register my braking psi, but no mater what scenerio I ran, every single time i roled out of the throttle and exhaust brake kicked in, no brake psi %% would register in trailer brake gauge. Now maybe if i were plugged into a trailer it would do something different, well see in a few weaks.It looks like the trailer brake is applied with no trailer when you press the brake pedal, but not when you have the exhaust brake engaged. So to answer my own question, you do need the trailer connection (or at least without a trailer there's no in-cab evidence of trailer braking when exhaust brake applies).
Fyi: wife was texting with oldest grandson was how I got away with the 103, she about beach slapped me, when I told her, she said we were just riding so smooth in this tank I never even noticed.
