Hello everyone. I am in need of some help. I purchased the LED lights, the brackets, the bezels, the light switch and a jumper harness that will have to be modified. I have ALFAOBD and the security bypass cable, and as well the Autel MS906BT with the 12+8 cable.
I need help though. I read through a lot of posts about this subject, but seems like many are wiring these up to the aux switches. Once I thought I had seen a thread on an install that had shown pictures of the wiring being done but cannot locate that particular thread now.
I want to try to wire the lights up to the truck using the factory light switch. Where do I wire the actual left and right wires from the jumper harness? Is it under the hood somewhere on the driver's side in a connector there? Or do the wires have to travel all the way back to the BCM under the dash and go into C1:1 (left) and C4:13 for the (right)?
Thank you so much for any help anyone provides me, so appreciated. Thanks, Ken
