Truck wont start. Please help!
Texasram1
2022 diesel mega cab
Parked it outside last night, and of course it rained a lot.
Started it this morning w/o issue, but only had to move it 10 feet.
Tried to start it maybe an hour ago, and no dice.
Said it was doing a diesel preheat. Then nothing but a loud pop/click through the stereo.
Tried a fully charged jump box and still no dice.
Here is a vid of trying to start it on jump box
Help!
For future reference, you need to put the jump box on the engine block side of the IBS that's on the negative battery post.
If you try to jump directly to the battery post, the BCM/PCM doesn't know SOC of the battery/jump box and will not crank.
I dont follow. IBS on the negative battery post?
I put my jump box on the driver’s side battery. Red to red, blk to blk.
This has worked in the past, but certainly coulda been dumb luck.
Proper Battery Charging
In-Vehicle systems is not an issue. Please note to charge through the IBS or tie negative clamp to
Body/engine ground. Customers, Dealers, Mechanics, and Engineers usually want to place the
negative clamp on the pole of the battery. This creates Blind charging. “DO NOT BLIND CHARGE”
See below proper connections for charging.
Same goes for jumping.
Read this thread from the link to the end.
