Tire Pressure Sensors
I put 37's on my truck recently with factory TPMS. Manufacture says it can go up to 60 PSI which I am at, but the TPMS keep going off line. Can a dealer reset for 37's or not able to do and live with the sensors going on and off?
2024 and before you can use a tool to change your pressures, if its a 2025+ you can only choose factory tire options and the pressures that come with them. Have to wait for full programing to be available on the new architecture in the 2025+ trucks.
Thanks for the info. Not so much worried about the PSI vs TPMS sensors that won't stay online with the new tires. And yes it's a 2025 model.
Just took my 2022 RAM 2500 to a shop that has the JSCAN utility used to enter the Computer Module to make these changes (TPMS). According to the mechanic they are unable to bypass RAM Security to make the change. So Apparently the security issue goes back as far as year model 2022. Is there a Security Code needed to get past the RAM security on the earlier models?
2022 models don’t have any of the issues that 2025+ trucks do. You just need a bypass cable, same as all other 2019-2024.
Thanks jsalbre! Can you recommend a particular By Pass Cable that will work? I'm searching Amazon and only finding Bypass Cables up to and including 2020 models.
The Kaodtech cable works best on the 2019 and up HD Rams.
You are Awesome! Thanks a Bunch! May the Lord Bless you and your family extra special this Weekend!
Recently installed Nitto Ridge Grapplers, 35x12.5x17 on a 2026 Ram 3500 dually. Is there anything available to reprogram the TPS? Dodge service said they are unable to do it. Thanks
Stock rims? Fighting balance/vibration issues & curious if you’ve experienced the same?
