Odd noise
Crashresq21
Morning guys,
So for a while now when the truck flexes or I take a left hand turn with a bump or any sort of non flat surface I hear this binding noise from under my feet only on the left hand side of the truck. Haven't had to change the crawl under and dig in. 2020 RAM 3500 crew cab single rears, 6.4.
I've had a couple people tell me it could be body mounts but there's more of me that says it's a suspension issue.
Anybody have any thoughts?
Morning guys,
So for a while now when the truck flexes or I take a left hand turn with a bump or any sort of non flat surface I hear this binding noise from under my feet only on the left hand side of the truck. Haven't had to change the crawl on the Nathan really dig in. 2020 RAM 3500 crew cab single rears, 6.4.
Could be a rubber bushing on the sway bar or control arm? Very tough to diagnose over the www.
More than likely body mounts. My 2020 did the same thing and I believe there is a service bulletin/recall on those but I can't confirm.
My 2021 3500 doesn't do it
My 2020 does the same thing, on both sides. The suspension components are all tight, operating correctly. It's most likely the body mounts. I'm actually going get the truck scheduled for service this week.
Body mounts. My neighbor has a 2020 doing the same thing. We compared trucks and the body mounts are totally different and there is a service bulletin for this.
Solved as everyone basically stated. Torqued all mounts to 90 foot pounds. All good, thanks for the help!
It's good that the torque fixed it... Though you should know it's temporary. I'd recommend getting them replaced per the tsb. The new ones are a completely different design. This is stated 100% from what I went through with mine. Post tsb parts.. Zero issues
Mine truck is making a clunk when a drop the left front tire of a small 4 inch ledge/bump.
I’m going to loosen and retighten my front cab mounts to see if that fixes the issue.
Does anyone know what the updated part number is for the cab mounts?
Also does anyone have pictures showing the difference between the old mounts and the updated version?
If you decide a dealer appointment is in order, then please let us know! Otherwise, we recommend checking the Mopar site as well and searching by VIN for all applicable parts and accessories: https://store.mopar.com
Hannah
Ram Cares
Mine has always done this
Does anyone have the required part numbers, for 2019 limited ?
Maybe... But it shouldn't.
My 21 also did it when it was new, dealer swapped with new body mounts, never heard aqain in over 100k.
I wasn’t saying it was normal. I also would eventually like to fix this
Are bulletins warranty fixes? I’m way out of warranty.
