Telescoping steering wheel?
WXman
Kentucky
One thing I do not like about my Tradesman is the lack of a telescoping wheel. When I get the seat where my legs are comfy and my feet aren't bent weird to use the pedal, my arms are almost straight out. Ram didn't do a very good job designing this for men.
Does the Bighorn 2500 have a telescoping steering wheel? Could that be retrofitted into a Tradesman?
No HD Rams have a telescoping wheel, only the 1500s have one.
4th gen cab doesn't have telescoping wheel, HUD, flat floor, etc.
In fact, what's really going to drive you nuts now until the end of time is me telling you
the wheel is offset from the center of the cluster.
Oh, well GM did that for years. I had a couple of GM trucks where the steering wheel was at an angle to the dash. I never knew the reason for that, but it was noticeable to the naked eye.
I hope to see an updated Ram cab before I die. I'm 47 now....it MIGHT happen....
Same, I’m in a 1500 now and while the old cab was plenty fine for 2009 the DT trucks have so much better ergonomics/comfort/noise etc. I’d probably have already moved to a 3/4 ton by now if they’d re designed the HD trucks the year following the 1/2 ton like normal but alas. Maybe they will have the new Canbus worked out by the time they clean sheet the HD line.
What is the CAN bus issue?
I have a 2026 2500. I have the same problem, get seat adjusted, pedals set full forward and the brake pedal still sets too close to me.
Humans definitely come in odd shapes and sizes.
I thought me being a goofy ass giraffe who is 6’ tall, with only a 31” inseam, would make me the hard one to fit vehicle controls to
I'm the same proportions pretty much and in the process of narrowing down a 26 2500. My right knee has been smashed in the dash on test drives, I have about an inch of clearance in my GMC 1500. I did not adjust the pedals on the test drives (I didn't know you could). Have you been able to find a comfortable seating position after adjusting the pedals? There's another company that sells a steering wheel spacer: https://spacershop.com/product-category/dodge/
I emailed them about this. There is a website based out of Europe that sells the same product and the US guy said they got them from them. The US company said they are switching manufacturers and are in trial phase of the new one. Looking for someone near them to try it out as of a few weeks ago.
That would be great news, thank you. Would this be the EU website by chance (if you know)? https://spacershop.com/product-category/dodge/
